- This topic has 9 replies, 3 voices, and was last updated 10 years, 10 months ago by .
Hi all,
I’ve been experimenting with shorter crank lengths on my everyday road bike for some time and have really got used to 165mm now. It feels like a slightly smaller rotation circle (which it is of course) compared to previous 172.5mm, although I did try out 170mm on the way to running 165mm. I was able to use a relatively inexpensive track chainset to experiment. The pedal action really is a lot smoother and I really like it.
Problem comes along now with changing the good road bike. Its running Campy and they don’t make a crank length shorter than 170mm from what I can see. The options seem to be Rotor, FSA and Sram. Starting with Rotor, despite trying to contact them they could not tell me what the predal / axle offset is compared to Campy Chorus (I have measured the Chorus cranks at 12mm by using a straight edge guide and a steel ruler). The Rotor cranks look almost stright to me and while I do not have a major problem with ankle clearance, I do not want to go back to old-school straight alloy cranks. This is a pity since I could swap the Campy chainrings on the the Rotor cranks (or can I, not totally sure).
FSA, I just don’t care for the look of the current range of chainsets from them, so this leaves Sram. Everything about the Sram Red chanset looks ideal actually. Just not sure how the tooth geometry of the chainrings will work with the Campy Chorus front derailleur (I am running a KMC 11-speed chain).
So to get to the original question, is anyone currently running this setup and could pass along some comments?
thanks,
Bill
