- This topic has 3 replies, 4 voices, and was last updated 10 years, 6 months ago by .
Need a bit of advice. I have a b’Twin 500 which came equipped with a Claris crankset with Octalink (long “splines” I believe.
I’ve worn out and replaced the cassette, chain and crankset but I’m net exactly sure which is the correct replacement BB. There seem to be several ranging from 68 X 113 to 73 X 126 and various combinations. I’m not entirely sure from where to take the measurement – I’ve measured the housing for the BB which appears to be 68mm so I’m guessing that the 68 bit will be correct.
The Claris crankset is a triple so that mey have some bearing on, well, the correct bearing.
On a happy note my b’Twin has helped me to lose 50lbs (23kg) this year So I’m halfway to my target of 100kg (from 145kg). It’s no wonder some components need changing is it? All credit to Decathlon for (maybe inadvertantly) building a road bike for a hippo) but since there seems to be no way of asking them the question I thought a fellow b’Twinner might know the answer.
Another question…
I’m now onto my third set of wheels! Being larger puts a lot of strain on the spokes particularly at the bend on the hub end. It occurred to me that if I added a suspension seat post to my B17 saddle then that would remove the “straight through” shockwave when the rear wheel hits ridges on the road and uneven joins on so-called cycle lanes. Whooly Hat Shop have just sent me a new rear wheel with Shimano sealed bearing hub, Mavic rim with eyeletted spoke holes and double butted spokes. Looks really strong but I have to carry spare spokes everywhere, as I assem adept at snappting them at the hub. On the plus side I’m getting really adept at respoking and truing up a wheel. No experience is ever wasted 🙂
