- This topic has 6 replies, 6 voices, and was last updated 11 years ago by .
evening all,
I have some Elite rollers with built in resistance. Have carried out a CP20 test with warm up drills and 5 min max output effort in build in.
I have also done the same drill/sets and carried out the test on the road, both server all times with being general rested the same for rollers/road.
My roller results are 10-15% less than road. Any reasons for this?
If I train on the rollers this winter at a reduced FT rate, which is a chuck lower than road, will my road power output reduce, as I’m not pushing the higher power watts?
Hope I’ve been clear in above and appearcite any advise/help on this.
ta
