What quick fit mudguards for disc road bike?
  • This topic has 10 replies, 9 voices, and was last updated 11 years ago by Simon E.
  • #24902
    Deveron53
    Hi all, I’ve looked at all the reviews I can find and can’t seem to make my mind up. I’d like some full-coverage mudguards for my Genesis CdA. I’m using 28mm Schwalbe One tyres on Stan’s Crest rims.
    I’d like to be able to remove them for fine days as well!
    Thanks in advance
  • #861577
    Deveron53 wrote:
    Thanks for the info chaps. I’ve seen a pair of halfords own brand guards that have mid-stay quick fit attachments. They may be a bit narrow but at £15 may be worth a punt…
    If they’re narrow you could find you get more spray than a pair with proper coverage for your tyres. But for £15…
    #861575
    carytb
    Bontrager full length ones
    Bontrager full length ones have been the easiest ones To fit and adjust. They just don’t look very good though.
    #861573
    Deveron53
    #861571
    CXR94Di2 wrote:Full mudguards
    CXR94Di2 wrote:
    Full mudguards fit and ride all winter.
    +1. Tortec full length (black, not chrome).
    There are clip-on alternatives like Raceblade Longs but they’re all compromised. A bike like the CdA deserves to be suitably atired for adverse conditions 😉
    #861569
    pga
    Fitting full length mudguards
    Fitting full length mudguards can be a problem where the disc brake projects outward beyond the fork and rear stays ends. Spacers will be needed to allow the mudguard fixing bolt to engage the mudguard eye. Fixing a rear rack can add to the problem. Topeak make rear racks with disc mounts that provide the space and allow a normal size fixing bolt to be used. I have not tried this yet but hopefully a longer bolt would take a mudguard fixing as well.
    #861567
    BBRAP
    I had to swap out my 25’s and
    I had to swap out my 25’s and put 23’s on to get cruds to fit without rubbing.
    #861565
    nadsta
    I use Bontrager full guards
    I use Bontrager full guards on my 28 mm tyred gravel bike. 10 minute job to fit/remove. Around £35 I think.
    #861563
    Leodis
    crud roadrace will only fit a
    crud roadrace will only fit a 23 tyre without rubbing, 25 at a push but it will catch and skweek a lot in my experience of them last winter.
    #861561
    Bob's Bikes
    I have a disc road bike that
    I have a disc road bike that doesn’t have rack mounts so I am going to use crud roadrace mkII’s and just cut and glue the arms to fit as the arms will have to avoid the caliper mount points.
    #861559
    CXR94Di2
    Full mudguards fit and ride all winter. I used whyte mudguards on my Boardman CXR. They worked very well. Don’t worry about the odd dry day if you’re going to ride through winter
