Self-cleaning jockey wheels!
  • This topic has 14 replies, 9 voices, and was last updated 11 years ago by wellcoordinated.
  • #24899
    userfriendly
    Someone with materials science fu, please …. invent them.
    Failing that, I’m looking to hire one or two tiny-fingered elves.
    X(
Viewing 14 replies - 1 through 14 (of 14 total)
  • #861533
    wellcoordinated
    bikeboy76
    bikeboy76 wrote:
    wellcoordinated wrote:
    Clean the drive train after every ride.
    Pffft… lifes too short or you don’t ride enough or you have a personal mechanic or don’t work.
    or you’re just a lazy git :))
    #861531
    userfriendly
    Thanks, I shall try that on
    Thanks, I shall try that on my dry weather bike. Would be nice not to have that black gunk all over the shiny silver alloy Athena parts.
    #861529
    sergius
    I’m using this
    I’m using this stuff:
    http://www.wiggle.co.uk/squirt-chain-lube-120ml/?sku=5360593459
    r.e. the comment about a new chain, unless you degreased it first that was probably your problem.
    When I switched to a wax based lube, I degreased my chain (had about 1000 miles on it) a couple of times (which with hindsight was possibly still not enough, it took 3-4 applications of wax before the oil was all gone). I then applied the wax to the inside of the chain fairly liberally, before giving it a good spin to get rid of the excess + a wipe down; basically you just want the inner rollers coated in wax.
    I always do this after a ride so it has a chance to penetrate and dry out before riding it again.
    After a ride I just clean the chain with a old rag – no degreaser or anything else required, before re-applying the wax lube.
    I’ve not done a huge amount of wet miles on this (best bike + weekend warrior). I’ll admit I’ve no plans to switch to wax for my winter bike, wet lube all the way there.
    #861527
    userfriendly
    I’ve tried wax once, applied
    I’ve tried wax once, applied to a brand new chain, and it made the entire drive train feel rather noisy and rumble-y. Then again, there may be nuances to using wax instead of normal lube that were lost on me, I’ll happily admit I may have been doing it wrong.
    Are there specific products you can recommend? Things, apart from wiping off the excess after a ride, that someone can easily get wrong when using wax?
    Totally up for trying wax based lubes again – I mean, if wax is good enough for my legs it may be good for my chains too …
    … in the meantime I’ll be at the bottom of my garden with the butterfly net trying to catch me some of them elves. They’re quickly moving little buggers!
    #861525
    sergius
    I’ve switched to wax based
    I’ve switched to wax based lubricants from oil, they are a teeny bit more effort to use (you need to wipe of excess wax after a ride) but you retain a nice shiny chain and there’s no oil to get everywhere.
    I spend 10 minutes after a ride wiping off the excess and re-applying the wax, once you get practised it’s not especially onerous.
    If you are a weekend warrior I’d recommend trying wax. For commuting/everyday usage I’d think it’s probably a little to much effort.
    #861523
    fukawitribe
    brooksby wrote:mike the bike
    mike the bike wrote:
    Don’t use oily stuff on your chain and the problem goes away.
    Erm – you mean, like, chain lube? What do you use?
    http://logok.org/wp-content/uploads/2014/05/elf-logo.png
    #861521
    Leviathan
    wellcoordinated wrote:Clean
    #861519
    mike the bike wrote:Don’t use
    #861517
    userfriendly
    Do I dip the elves in oil
    Do I dip the elves in oil instead?
    #861515
    mike the bike
    #861513
    userfriendly
    But I want elves
    But I want elves 🙁
    #861511
    wellcoordinated
    Clean the drive train after every ride. Spray WD40 generously over the jockey wheels, then with a cloth between your thumb and fore finger gentle grip the exposed part of the jockey wheel while turning the crank. Comes clean in seconds. If you need a toothbrush you are not looking after the drive chain enough. Also doe not need any elves.
    #861509
    medic_ollie
    They’re pretty easy to take
    They’re pretty easy to take off so you can give them a real good scrub.
    #861507
    kev-s
    old tooth brush
    old tooth brush 😉 😉
