- This topic has 12 replies, 4 voices, and was last updated 11 years, 1 month ago by .
Recently brought a S-Works Tarmac which comes with S-Works FACT carbon, OSBB, 52/36
Std rides this is fine no issues on the hills these rides are all sub 90k, shorter hiller rides are also okay even with 20% gradient I did my fastest time.
Longer rides with more big hills I find I struggle when the gradient gets up around 10% I get left behind because I am struggling to turn the crank.
I cannot afford to replace the crank yet so was thinking just change the cassette as it currently has 11-speed, 11-28t on it
Is changing the cassette going to help at all?
I am doing Genting mountain in Jan 2016 which is a particularly long climb and its a once in a lift time trip so don’t want to be failing because I cannot turn the cranks.
I am assuming either a FSA SK Light or a Duraace Crank would be the best option as other components are duraace
