- This topic has 14 replies, 6 voices, and was last updated 10 years, 10 months ago by .
I have been trawling help pages and generic guides on the net about gearing and my mental gears are worn out.
I think I need to make some changes to my cassette ..
Having got a entry level road sportive to get fit, im now finding im not using the lower gears.
From what I have worked out its 50 43 at the front and 11 32 at the back – Merida ride 100.I was using the lowest gear combinations all the time when I started out a couple of months ago.
Now (same routes with hills) im rarely off the big gear at the front, when I do hit the crawler cog at the front I rarely feel the need to use the last 2 big cogs at the back. Im also finding that some of the gear changes in the middle are quite a clunk when trying to maintain momentum, im assuming that could be improved ?So… my questions.
Is it usually just the rear cassette that is changed ? any benefit in my case changing the front gears as well ?
Can they be easily changed ?
Any recommendations to go for ? … My preference is Amazon
thanks.
