- This topic has 2 replies, 3 voices, and was last updated 11 years, 1 month ago by .
Stronger than steel, super thin, flexible, so many options as to its use. The wonder material has now found its way into an obvious cycling application, tyres. Apparently mixing it into tread compounds to produce more effective and lighter seems the way to go, but is it? I have thought since it was first invented that puncture proofing tyres was the way forward, if the material is as flexible as stated then why not coat tyre insides with the stuff, or, laminate the casings, better still why not innertubes. Lightweight tubs and tyres that are puncture free and long lasting, what a dream. No doubt for business there will be a light bulb mentality that makes sure we don’t benefit.
