- This topic has 17 replies, 16 voices, and was last updated 11 years, 1 month ago by
therevokid.
September 16, 2015 at 9:10 am #24806
tonylowe
I’m looking to buy some appropriate prescription sun glasses for cycling. I have a -3 prescription which has meant that my current pair look a bit like jam jars… not a look I was after! Does anyone have any suggestions on brands, models and sources which would avoid that look?
Thanks
therevokid
+4.75 so inserts and Rudy
+4.75 so inserts and Rudy Projects … and once you have an insert
your own optician can get it re-glazed as and when (mine are now
varifocal 🙂 )kev-s
abudhabiChris wrote:kev-s
abudhabiChris wrote:[quote=kev-s]Contact lenses are one option but if your a sweater then they can be a pain as when the sweat goes into your eyes it can cause the contacts to move and irritate your eyesI have Oakley frames fitted with prescription transition lenses (im -3 in both eyes)
There for everyday wear and are just as good on the bike as they are off it
Cost £149 all in from http://www.selectspecs.com/%5B/quote%5D
I know it wasn’t the OP’s question but just to comment on contact lenses and sweat in case others are reading this… it hasn’t been my experience that sweat causes any issues with lenses.
Quite the opposite. The salty sweat runs into your eyes and helps to moisten the lenses. Then you can just wear whatever sunglasses you want on top – I have Oakleys with some different lenses for different conditions.
And as I’m using daily disposables year round to ride in the UAE I think I have a fairly good experience base with sweat and lenses.
See for me its the exact opposite, sweat runs in my eyes, stings and dislodges the contacts, Ive had to refit one by the side of the road using my sunglasses as a mirror, balancing the glasses on my bars
Tried various sweat bands (including a gut-r which i still use) to help combat to no avail so went with prescription sunglasses
KirinChris
kev-s wrote:Contact lenses
kev-s
Big Engine
I have an old pair of Nike
I have an old pair of Nike prescription shades that were from Specsavers, but unfortunately they’re coming to the end of their life.
They’re a ‘medium’ size, and the arms wrap around. Five years ago they were approx. £90.Having recently researched the market in local opticians, you’ll struggle to find a decent pair of prescription shades for a good price. They either have crappy looking ones for £70-£100, Oakley’s (about £300), or not much else.
Unfortunately there doesn’t seem to be much about that’s in the middle ground; most at that price point have changeable lenses or are sport goggles.
I’ve recently acquired some Nike ‘Black Adrenalin’ from Boots (£200), but have yet to wear them (they’re a present… not long now). Although not cycling-specific shades, they have big, mirrored lenses and wrap around. The nosepad part is integral, meaning it won’t perish (a problem with my old shades). Hopefully these will be a winner.
I too use contacts; once they’re in okay then they work well, and you can use all manner of different shades. But if you sweat a lot then that could potentially mess with them, you can’t rub/wipe your eyes, and they don’t have quite the same clarity and surety as prescriptions. You’ll also need to carry glasses, otherwise if you have a contacts problem you could find yourself myopically struggling home! Also, at £0.50-£1.00 a time, eventually you’ll have paid for a pair of prescriptions, that ultimately are less of a faff and can be slung on anytime.
Jez Ash
another vote for optilabs.
another vote for optilabs. we reviewed some (http://road.cc/content/review/137578-optilabs-switch-glasses) which I liked a lot. Your prescription is such that Oakley etc could make lenses no problems – mine is too strong and they couldn’t (although I’ve had Optilabs glaze two pairs of Oakleys in the past).I’ve currently got a pair of Lazer Magneto sunglasses for which you can get an insert (larger and less visually obtrusive than some) which I had glazed by Optilabs. If you don’t like the insert-style, then they’ll glaze just about anything for you, I think.
rjfrussell
daily disposable contact
daily disposable contact lenses.BBRAP
Over the years I’ve used
Over the years I’ve used various online suppliers utilising my prescription from my opticians. I have never been completely happy with the results. I went into Specsavers (yes the highstreet bunch) and spoke to them. They showed me a number of suitable frames (including Rudy). They tested my sight (free of charge), and measured my current varifocal specs (not from them). As I wear varifocals they suggested that the distance (top bit) of the lens should be adjusted so that my vision was good when looking through the lens at a slight angle (so I don’t need to crane my neck back), something I’d never even considered. They got me to adopt a cycling position and took some measurements (much to the amusement of others in the shop) and worked out a price. I chose a wrap around style with varifocal self dimming (can’t remember the proper name) lenses for less than £200 (which is quite good for varifocals). Single vision would be around the £100 mark. Very pleased with the results as I can now see properly without the previous neck flexing. My prescription is quite high 4+ as I’m pretty bat eyed, the lenses look thick but once on and out in the light (when they tint up) they just look like any other cycling specs.xbr976
I’m extremely myopic and have
I’m extremely myopic and have used Rudy Project Magsters with the inserts for several years. I bought them at a dedicated Rudy shop where I think an experienced salesperson can help make sure that what frame fits best depending on the shape of your face. They can also help in determining the focal point of the insert if they can observe you in person. So, I’d recommend shop over buying on-line. Also, in California glasses deemed prescription are non-taxable.I have various lenses. Often I will start a ride wearing dark lenses, but switch out to a clear lenses for darkening conditions. Rudy’s are relatively easy to change, but not something possible to do while riding.
I haven’t experienced any discomfort using the glasses while riding but opt for regular sunglasses while driving.
I’ve also heard of counterfeit Rudy’s being sold on-line. I doubt that’s a problem if you buy from an authorized dealer.
justinberman
I have a pair of Optilabs
I have a pair of Optilabs Sprint with transitions lenses. Pretty good value (compared to prescription Oakleys anyway), would recommend them, although I’ve had to do a small repair on one of the arms with a bit of duct tape after 18 months, but other than that, they perform pretty well.arckuk
I wear regular glasses
I wear regular glasses day-to-day and for commuting, but switch to disposable contacts and standard sunglasses for ‘proper’ rides. The lenses are also useful for snorkelling and skiing etc, and only end up at ~ 50p per day.tonylowe
Awesome thanks. I’m now
Awesome thanks. I’m now looking at the range offered by Optilabs which I hadn’t come across before. Any advice on models and lens types? The Ultra 2000 lens sounds great but is expensive… anyone have these?TrevA
Another vote for Optilabs
Another vote for Optilabs here. I’ve had 2 pairs in 6 years. In the middle of those I also used some clip on inserts but found you get condensation and sweat between the inserts and the sunglasses lens and I also found that my eyelashes brushed the inserts. That’s why I went back to Optilabs prescription glasses. Mine are photochromatic, they go clear in low light conditions so I can also use them at night. They are about £150 but well worth the money.700c
I got ones with the insert
I got ones with the insert and they’re not great, TBH. Cheaper than cycling-specific prescription glassess (e.g. from Oakley etc) but as the insert is smaller than the outer lens, you do get reduced visibility when looking over the shoulder. Plus they do push slightly against eyelashes etc.Man of Lard
All the
All the optometrically-challenged chaps I know swear by Optilabs. -
