Annoying Buzz / Rattle
  • #24800
    ibr17xvii
    I have Shimano Claris shifters & on the shifter on the left hand side only there is an annoying buzz coming from it particularly on not great road surfaces.
    I thought initially it was coming from the plastic name plate on the top but now I’m convinced it’s coming from where the cable goes into the shifter itself at the side.
    Anyone experienced anything similar & had any success in getting rid of it?
  • #859709
    Nat Jas Moe
    remember the washer / collet
    remember the washer / collet inside
    #859707
    ibr17xvii
    Managed to get a bit of tape
    Managed to get a bit of tape round where the cable enters the shifter on the side which hasn’t made a blind bit of difference, still a very annoying buzz sound coming from 1 side.
    Could try a bit more tape I guess but as I discovered if you put too much on, when you put the cable back into the shifter the tape just comes away & is bunched up at the end of the cable.
    Not sure what to try next………if anything ~X(
    #859705
    ibr17xvii
    Cheers I’ll bear that in
    Cheers I’ll bear that in mind.
    Managed to loosen the cable & reseat it in the housing so I’ll take it out for a spin & see if there’s any improvement. If not I’ll go with the poster above suggestion & try a bit of tape around it to see if that will stop it.
    If none of that works, no idea!
    #859703
    Nat Jas Moe
    There is a washer type thing
    There is a washer type thing in side just below the top plastic cover which rattles of my shifts, drives me potty at times it could also be the cause of your buzz. Just another suggestion.
    #859701
    ibr17xvii
    HalfWheeler wrote:Take it to
    HalfWheeler wrote:
    Take it to a bike shop.
    I was hoping to avoid having to do that if it was reasonably simple to do as a novice.
    #859699
    HalfWheeler
    #859697
    ibr17xvii
    vonhelmet wrote:You’d need to
    vonhelmet wrote:
    You’d need to release the inner cable at the mech to release the tension in the cable in order to get the cable outer out of the shifter.
    Anyone able to point me in the direction of an idiots guide how to do this before I inevitably break something? :))
    #859695
    ibr17xvii
    I need to have a go because it’s getting a bit irrittating now but sounds a bit complicated for a novice like me…… 😕
    #859693
    vonhelmet
    #859691
    ibr17xvii
    vonhelmet wrote:I have a
    vonhelmet wrote:
    I have a similar problem on my Claris shifters. I think I’m also developing something similar on my Tiagra shifters after riding in an absolute deluge, which would be deeply irritating.
    On my Claris shifters I think it’s due to the cable outer rattling in the port where it enters the shifter. I might try to fix it by putting some electrical tape round the cable end so it’s a bit fatter and doesn’t have so much room to move in there.
    It’s deffo coming from where the cable enters the shifter itself I’m sure of it. Maybe as you suggest it’s worth reseating the cable or wrapping some tape around it.
    Is it just a case of pulling the cable hard (ish) & it will come out of the shifter? Never removed it before. Didn’t want to break it!
    #859689
    vonhelmet
    #859687
    FatAndFurious
    If you wear a watch with a
    If you wear a watch with a metallic link strap, check it’s not that first.
    Been there.
