- This topic has 12 replies, 6 voices, and was last updated 11 years, 1 month ago by .
Hi all,
Recently I found Shimano released a new 6800 cassette, with 14/28 cogs.
And I’m also considering change my current 11/32 cassette to X/28 cassette, any ideas?The reason I’m considering change from 11/32 to X/28 is that, although I’m climbing for half of my ride,
but the the highest climbing routine here is only about 7.5% average and 14% max(only about 100+ meters long).Even with a semi-compact(52/36), the 36/32 ratio seems too low, but if changed to 36/25, it seems too high for the 6~10% climb.
For 14% climb, 32 cog is good, but when I have to climb out of saddle and the ratio is too low again.I’m quite sure the 28 cog should be a quite good choice for climb.
But I’m unsure between 14/28 and 11/28.
As for normal flat use, 36 with 14~15 will give me quite a good speed near 40kmh,
and of course, without chain rub. I seldom use the 52 chainring.
I assume 11/28 will give me quite the same result on flat.
And for climb, 25~28 is much smaller jump than old 25~32 jump.On the other hand, if use 14/28, I’ll get much smaller gear jump for every cog, but I may need to use the 52 chainring
for flat.So any ideas?
Thanks
