- This topic has 1 reply, 2 voices, and was last updated 10 years, 10 months ago by .
I have a Carrera Virtuoso which i am rebuilding. The crank i had on was a 175mm 42/52. I know my arm length needs to remain the same but does the crank have to remain 42/52 or could i use a 39/53? Also the existing bottom bracket is a square tapered type. can i remove and change to a hollowtech or shimano ultegra octolink? Thanks Mark.
