training for a century in 1.5 hour sessions
  • #24493
    Nate Dawg
    I’ve signed up for a pretty flat (around 3000ft of climbing) 100 mile ride in around 8 weeks time, I’ve never ridden this distance before, however although I have time to train, the bulk of my training time will be in 1.5 hour sessions, so I was wondering if any one had any training tips so I can get the best out of the sessions I have.
    at the moment I can comfortably ride 40-50 miles with 3000-5000ft of climbing, (I live in the Peak District surrounded by big hills!)
    Not interested in setting a fast time on the century, I just want to make sure I get round it…..
    Thanks
  • #855005
    Saddle & food are likely the
    Saddle & food are likely the biggest concerns.
    Is there a day when you can do two of these 1½ hour rides? I’d avoid the big hills, do long stretches into the wind (treat it as testing your resolve), ride a medium-hard pace for as long as you can hold it. Then a bit longer – grit your teeth, this last bit is what makes the difference to your condition.
    #855003
    Stratman
    I’d echo the comments about
    I’d echo the comments about eating and drinking – worked for me when I did long rides
    #855001
    Judge dreadful
    Don’t underestimate the
    Don’t underestimate the mental component. I’ve not had problems with the physical side of it, but telling your ‘better’ instinct to shut up, is easier said than done:
    #854999
    Nat Jas Moe
    When I made the jump from
    When I made the jump from just riding my 8.5 mile, each way, commute to doing metric and then imperial centuries the hardest thing was eating and drinking properly and then ensuring I was comfy in the saddle. It wasn’t the distance that was a problem. Like you I did not set out for the best speed but found that the time I achieved was quite good, 6h 25m including the feed stops for the imperial. Just that bit of rub when I realized that I was 3min too slow for a gold. Just keep doing what your doing and ensure you eat and drink regularly as you go. Best of luck.
    #854997
    CXR94Di2
    I would do high intensity
    I would do high intensity sessions of 5 ,10 20 mins. Then it will be easier later in the ride. Long rides are more about drinking eating and being comfy. If you can ride 50 then you can do 100
    #854995
    Judge dreadful
    Get out on the road, plot a
    Get out on the road, plot a nice interesting route, do it. If you make the route interesting. You won’t even notice the distance.
