- This topic has 12 replies, 8 voices, and was last updated 11 years, 3 months ago by .
So 2years ago I rebuilt my old Principia after many years of being sat in the garage, I opted to go with a Dura Ace 7900 10 speed groupset to replace the old 9 speed Ultegra set. One of the things I did was to go to a compact 50/34 chainset with a 28/11 cassette as I really couldn’t manage the hills like I used to. I also went from 170mm cranks to 175mm which made a huge difference to climbing as I have always been more of a low torque, high cadence rider rather than a grinder and this seems more apparent in my older age!!
I am now much fitter (I zipped around the recent Velothon Wales course) and now have the opportunity to upgrade to a 9000 11 speed set up (I have enough Evans Cycles vouchers through work). I am considering a semi compact 52/36 chainset with the same size cassette with 175mm cracks. One of the irritating things about the 7900 chainsets is that the rings are not interchangeable but they are on the 9000.
So 2 questions:
1. How much difference to the torque will where be in changing to a 36t chain-wheel compared with a 34t?
2. If I wanted to change the 36t to a 34t, for say a hilly sportif, will I also need to change the 52t to a 50t?Thanks
