iPhone GPS accuracy?
  • #24207
    rjfrussell
    Completed a ride with my wife today.
    I recorded mine on an iPhone 5C using Wahoo Fitness app- distance 17.2 miles
    She recorded the identical ride on an iPhone 5C (bought the same day as mine) using the Strava app- distance 17.8 miles.
    Has anyone else come across such discrepancies between apps/ devices?
    Does road.cc fancy doing a trial/ test into the accuracy of a variety of devices?
  • #849559
    wellcoordinated
    Pyranha wrote:When my wife
    Pyranha wrote:
    When my wife and I go out together on bikes, we often end up with slightly different distances – usually I’ve ridden further than her, which is a cause of some consternation. This is using an iPhone 4 and a 4s, and Strava on each. As far as I can see, it’s likely to be down to the way the program interpolates between known data, particularly when it gets false signals (eg if you’re in a built up area, bounced signals can put you in a quite different place, but I would expect a decent system to smooth those out)
    I suggest that you sellotape the two iPhones together (buttons facing outwards in case you need to answer a call) and then suspend them on a piece of string between you as you both ride along. This way your track should match.
    Some really daft couples have gone to extreme lengths to get their Strava tacks exactly the same. Basically they cut their bikes in half and then weld their respective halves together into single one, to make a thing that they call a Tandem. When riding this Tandem the iPhone automatically recognises that two people are on the same bike and it tells Strava to record the same track on each of the two iPhones.
    Honestly the lengths some people go..
    #849557
    ianbak
    I often record data using
    I often record data using both my Garmin and Strava on my Android phone, and it’s not at all unusual for there to be noticeable discrepancies between the two!
    #849555
    Pyranha
    #849553
    mistertaylor
    Also I think Strava “pushes”
    Also I think Strava “pushes” your gps data towards commonly used routes already in their system http://labs.strava.com/slide/ or something.
    #849551
    crikey
    If you rode for the same
    If you rode for the same length of time, but she went further, she’s obviously riding faster than you… đŸ˜‰
    #849549
    mduncombe
    I wouldn’t consider what you
    I wouldn’t consider what you see unusual. GPS accuracy is down to a number of things but most important is the view of the sky. One device might have a slightly better view of the satellites than the other or even be in view of satellites that the other cant see. The human body blocks GPS satellite very effectively BTW. The more satellites a device can see the better the fix but the also the position of the satellites seen makes a big difference as its all down to geometry and timing. So lots of satellite directly above you don’t give a great fix, you want them low on the horizon and all around you to get the best geometry. But then you don’t want them so low they disappear below hills and buildings, so your antenna relative height will also come into play.
    As already mentioned, the accuracy of the map data can vary between devices and even between revision of the map. One might be more accurate in one location but not in another.
    The software/firmware used to calculate the distances can vary in the way it samples the GPS data. Take a track file and load it to Garmin Connect and Strava and you will most likely see slight variations in the metrics presented.
    Antenna design and location can also have a big effect and in general the larger the volume of the antenna the better it works. Mobile phones have to compromise when it comes to antenna volume for obvious reasons.
    Any test would ideally need all of the devices to be tested at exactly the same time (GPS satellites are constantly on the move), mounted in exactly the same place and using exactly the same software/website to analyse the data. But at the end of the day, does it really matter if the GPS thinks you are within 3, 5 or 20 meters of where you actually are?
    Mobile phones although compromised in terms of antenna design do have an advantage of being able to use the internet to get up to data databases of which satellites are likely to be visible at a given time, which can help get a fix quicker and effect distance travelled. Some may even use rough cell tower positioning to narrow down even further what satellites to look for, again it helps with the maths and gets you a fix quicker.
    Best advice is power up the GPS in plenty of time before your ride, with a good view of the sky as is practical. This lets it pull in as many quality satellites as possible. If you power up a GPS, start moving before it has a good fix, its going to struggle as the data strings it gets from the satellites will come and go as you pass trees and houses, this makes the initial maths harder and again has an impact of the numbers you might see at the end of the ride. Follow the advice in this last paragraph and most modern consumer GPS devices will provide boringly similar accuracy. Trust me I did it for a living đŸ™‚
    #849547
    wellcoordinated
    Did she start stop the ride
    Did she start stop the ride at exactly the same time as you? The most likely explanation is that she exists in a parallel universe where they don’t have miles but some other unit of measure. When this happens the iPhone has to do a unit conversion. However there is a small error that creeps in during conversion from her universe to yours.
    Obvious when you think about it eh! :”(
    #849545
    allanj
    Some of the variation comes
    Some of the variation comes from the apps using different mapping rather than the GPS being different I think. I’ve certainly noticed a difference among the group when doing the same ride with different devices
