- This topic has 6 replies, 5 voices, and was last updated 11 years, 3 months ago by .
While out for a very windy ride over the weekend I realised I had lost my cadense sensor magnet connected to the crank arm.
I was looking into buying one from Ebay then did some digging and there is a suggestions from the states to use stronger magnets such as neodymium, however these conversations are nearly 5 years old and all the links on there are out of date.Looked at an online store in the UK who sells magnets but it doesn’t looks like they stock the correct size (something like 12.7mm outside diameter x 6.4mm inside diameter x 3.2mm thick) to attach to the peddle bolt as I was thinking of getting some with a hole so I can if needed use an allen key to take the peddles of as these magnets are supposed to be really strong.
Has anyone tried these magnets and recommend a stockist or someone recommend an alternative.
