- This topic has 3 replies, 3 voices, and was last updated 11 years, 6 months ago by .
hi
Can anyone give me advice on removing a fsa non-drive side crank arm? My understanding is the 10 hex bolt is unscrewed to tighten the crank arm onto the spindle (it has an arrow and “tighten”) and screwed in to remove the arm from the spindle. This isn’t working for me. When I screw the bolt in it goes loose and then starts to tighten again I then use an extension bar for some leverage but I run out of mussle and it still won’t budge. I gave it same sharp taps with a rubber mallet but it won’t budge. I could feel the frame flexing so thought I’d better stop. I’ve sprayed the thing with penetrating oil and will have another go tomorrow.
Any ideas? This should be easy
