Building up a frankenstein of a bike (Franken-Bike)
  • #12198
    fbhidy
    So I am curious about mixing and matching shimano 7/8/9 speed components. I am (re)building up an old Cannondale R500. I have the original Shimano RSX/Sora mix but I have a newer Ritchie 9spd wheelset and mtn cassette and a 9 speed tiagra right shifter.
    1. Can I just change out the chain and shifter,put on the wheels and adjust the rear derailleur?
    2. Will the 7 speed have the range?
    3. Also the 7 speed rear derailleur is a long cage (for a triple), will that work on a 11-32 cassette or will I need a mtn rear derailleur (I have an old Alivio) or will the shifter then not work?!?
    Can you see why I am calling this a Franken-bike! Why am I doing this you ask? Because the original right 7speed shifter is not functioning and more importantly I am basically broke and can’t afford a “real” bike or “real” upgrades.
  • #633409
    fbhidy
    Sweet! Thanks for your help.
    Sweet! Thanks for your help. I’ll let you know how it goes, maybe even post pics when it’s done!
    #633407
    dave atkinson
    should be no problems with a
    should be no problems with a double and a long cage mech, whatever the cassette…
    #633405
    fbhidy
    I am running a double up
    I am running a double up front, 52-32 I think. I’m at work so I can’t check it until I get home.
    I am hoping to use it for general road riding and I am out of shape. So I’m hoping the low gearing on the Mtn cassette will help get my fat rear-end up the hills around the Finger Lakes of New York State.
    #633403
    dave atkinson
    you should be able to, yes. there’s no indexing in the rear mech and it should have plenty reach for a nine speed cassette.
    are you running a triple (53/39/30) and an 11-32 cassette? if so that’s a capacity of 44 teeth which is more than any road mech, triple or not, will be designed to cope with – most long cage road mechs are around 36T capacity. Having said that, it’ll be fine. fit the chain so that it has the capacity for the big chainring to big sprocket ratio – the length of chain that it needs to go round those two cogs, plus two extra links. you won’t be able to use the small sprockets in the granny ring, but you don’t need to anyway. And don’t use the big-big ratio either, it’s bad for the chain 🙂
