- This topic has 24 replies, 19 voices, and was last updated 11 years, 5 months ago by
Stealth78.
March 22, 2015 at 7:04 am #23558
Zermattjohn
Went over something pretty sharp yesterday, which ripped a v small tear in the side of my tyre, about 1cm. Only noticed this when I put in the new tube and spotted the small bulge of inner tube poking out of the tyre. Question is, is the tyre buggered (only about 500 miles old GP4000s) or can it be repaired? Is the strength of the whole tyre screwed now its got a hole in it? Thanks.
Stealth78
I patched a barely used GP
I patched a barely used GP 4000 last summer, i used duct tape. It was a nasty puncture, a sharp metal piece that got stuck like a fish hook in the tread.I must’ve used 3 or 4 pieces of tape, changing the direction with each ply (not sure that made a difference) but it worked pretty well. I kept on riding it til it was retired. I never tried to fix a sidewall tho.
I was also tempted to use mono sealant but my leftovers were all dried out.
Matt eaton
I’d do a repair, depending on
I’d do a repair, depending on intended use. Commuting, shorter rides etc. I wouldn’t hesitate to do a repair (and relegate the tyre to the rear wheel as others have suggested).If I were using the bike to ride dozens of miles out into the countryside where failure might leave me stranded I’d probably take the hit and buy a new tyre.
Jimmy Ray Will
I’ve fixed enough tyres over
I’ve fixed enough tyres over the years to feel confident enough to recommend giving fixing a go.My preferred route is to stitch the hole, then soak superglue into the stitiching to harden. Then thoroughly roughen the inner surface of the tyre and fit a decent sized puncture repair patch. The patch is simply to stop the threads puncturing the inner tube.
Have fixed repairs up to 12mm in length.
Chuck
I’d be quite happy riding
I’d be quite happy riding with a tyre boot or something to get me home but then it would be changed. £30-odd quid is an annoying amount of money for sure, but personally it’s not enough for me to ride around on a damaged bit of kit indefinitely, especially for something that usually lasts a reasonable amount of time (for me anyway).CyclingLocations.com
I think new tyre is probably
I think new tyre is probably the better option.I have had quite a lot of “bad luck” with my GP4000s this winter and have finally decided to switch to Vittoria Rubino.
matthewn5
Two layers of gaffa tape at
Two layers of gaffa tape at right angles will do the trick. I’ve done hundreds of miles on a Vittoria Diamante Pro that hit a rock on the sidewall on a corner. It’s so strong. Probably too strong, might make a flat spot, ish.But as others said, do put it on the back!
giff77
bendip wrote:giff77 wrote:I
bendip wrote:giff77 wrote:I cycled for about 6months with a fiver stashed behind a small tear once. :DAnyone who’s had to suffer the indignity of Mary Gober customer service training will have a dollar bill (Helps reinforce the don’t pass the buck metaphor !)
I used mine on a vittoria corsa tyre, it got me past the 2000 mile mark after a tear on the sidewall after 300 miles..i did relegate it to the rear though
You suffered that indignity as well :O I had successfully erased that experience until your comment :”( I think I may have that dollar somewhere. Might relegate it to the saddle bag now.
Judge dreadful
Personally I would just get a
Personally I would just get a new tyre, but if it happened on the fly I tend to use a cut up toothpaste tube to boot patch any smallish cuts. I have got some tyre boots as well (little plastic strips for patching slices).MuddyGoose
I buy the Lezyne sticky patch
I buy the Lezyne sticky patch kits (http://amzn.to/1HrStRH) because I like the patches but it also comes complete with a tyre boot (designed for this purpose). They are supposed to be ‘get me home’ only solutions but I am riding with one stuck on the inside of my rear tyre at the moment and it’s doing fine.My hole is on the tread and also around 1 cm. On a Michelin Pro4 Endurance 25c. I had a gash on a really cheap tyre a while back and it just deformed so badly it was beyond repair.
JonD
A mate stitched up a tear on
A mate stitched up a tear on an mtb tyre some years ago with dental floss, lasted until he eventually replaced it – was lower pressure tho’, and the cut was hidden belw the knobbles.On a charity ride some years ago, a long-standing cut was open enogh for the tyre to start squeezing through and rubbed a puncture…was looking for something to line the tyre and the sticky charity number badge (falling off my jersey) was v fibrous and tough, ideal for the job. Lasted the remaining 30+ miles and until I replaced it, tyre had almost had it anyway – 1.5″ at 80 psi normally, dropped the pressure a tad.
If you do repair it, stick it on the back.
voodoorich
Section of sidewall from an
Section of sidewall from an old tyre, stuck in place with “Shoo-goo” (look it up) – works for me, although mostly MTB tyres, so lower pressures.bendip
FullGas
Super glue can do wonders on
Super glue can do wonders on tyres. Give it a try.
giff77
bikeboy76 wrote:giff77
bikeboy76 wrote:giff77 wrote:I cycled for about 6months with a fiver stashed behind a small tear once. :D
Was it one of those new plastic fivers from the future? Now there’s a tip for you.Surprisingly yes. It was a Northern Bank polymer one from about 10/15 years back :O Northern Ireland was the only part of the UK to have these notes which raised eyebrows when you tried to part with them here on the mainland. The standard ones are pretty robust being made from a mix of paper and cotton/linen though.
Flying Scot
I once patched one with a
I once patched one with a caramel wafer wrapper and 3 rubber patches.Lasted 15 miles on horrendous roads and 25 retweets ……
