- This topic has 4 replies, 4 voices, and was last updated 11 years, 8 months ago by .
Hi all
New to the forum but would appreciate advice from the masses. I’m currently in the market for a new turbo trainer and want to make the step up to a fluid trainer. I’ve read a lot of online articles/reviews and have come down to either the Kurt Kinetic or Elite Qubo. Any advice to help me jump off the fence and make a decision would be very welcome.
Cheers
Chris
My brain-dump of thoughts in the balance on each is:Elite:
•Elasto-gel roller which apparently has less slippage
•Design means bodyweight is used to press bike against roller so same resistance each time
•Easier fold/away and lighter unit (but plastic so could be flimsy)
•Recommended by a real person in a shop!
•I have an Elite trainer at present (although admittedly it has finally fallen apart which is why I have to buy a new one)Kurt Kinetic:
•Robust design with lifetime guarantee (but bulkiness could be an issue of store and is heavier)
•Unique (patented) design which uses coupled magnets instead of a shaft / o-ring meaning no penetration of the fluid container (a supposed problem of fluid trainers is that the o-ring can fail and the system can leak)
•Uses silicone fluid which is ‘thermodynamically neutral’ i.e. as you ride and the system gets hot, the resistance won’t be affected by it
•Supposedly not as quiet as the Elite (but no idea how loud/quiet this is, nor the other)
•No idea what the roller itself is made of (but not Elasto-gel)
