Changing road bike wheels?
  • #23333
    Tomj91
    Hello i got my first road bike just under a year ago this is the one i have:http://www.tredz.co.uk/.Cube-Peloton-Triple-2014-Road-Bike_66781.htm i am now look to buy new wheels but i dont nl what speed the rear wheel should be for my bike any help with this please?
    I understand it may be a stuid question but got to learn at some point. Thanks!
  • #833109
    2 Wheeled Idiot
    The wheels you buy may as
    The wheels you buy may as well be 11 speed compatible, this will allow you to upgrade the groupset in a year or twos time if you want and has no disadvantage whilst still using your current cassette.
    You will need a washer to fit/move over your current 8-9-10 speed cassette but this is a very easy job to do with the right tools…..or lbs.
    #833107
    Leeroy_Silk
    All you need do is count the
    All you need do is count the number of cogs on your current wheel, that’ll tell you what speed it is.
    #833105
    Yorkshie Whippet
    Two things,
    Wheels these days
    Two things,
    Wheels these days are either 11 spd ready or not. Many 11 spd wheel will come with a spacer so that you can fit 8/9 or 10 spd cassette.
    If you have a triple, am fairly sure you’ll have a 9 spd cassette that could be taken off your existing wheel, with the correct tools, and fitted onto new wheel. Make sure you are getting a Shimano free hub. Alternative is to get a new 9 spd cassette fitted by a bike shop, however you may need a new chain for it to mesh smoothly.
    Hope this helps.
