- This topic has 14 replies, 11 voices, and was last updated 11 years, 8 months ago by .
At the end of my tether with my 5700 rear derailleur on a Cannondale Synapse 5. It shifts up the 11-28 cassette fine on both rings but will not shift down (i.e. to smaller sprocket) cleanly on the large ring. The 14-13-12 sprockets are the worst. Its High/Low limits are correct and has been like this since new. I’ve replaced the inner cable and the outer at the RD but still it won’t index correctly. It hasn’t had any prangs so the hanger isn’t my first suspect. I’m guessing it’s crap routing or rough outer cable ends that are causing too much friction to allow the tension in the RD to release cleanly. Anything else I should be looking at?
Viewing 14 replies - 1 through 14 (of 14 total)
