- This topic has 35 replies, 19 voices, and was last updated 11 years, 8 months ago by
Nick0.
February 13, 2015 at 12:25 pm #23264
edster99
Hi all
Is there any UK available bikes that fit the following spec :
Belt drive
Internal hub gears (Alfine / Rohloff (ouch, spendy) )
Proper mudguard fittings
Normal frame (i.e not a folder)
Road bars (ideally, but at worst, the other 3 )I cant seem to find anything but maybe I am looking in the wrong place. Something like these, perhaps, or is there a distributor over here?
http://www.englishcycles.com/cat/custombikes/beltdrive/
Thanks
Nick0
I nearly bought one of these
I nearly bought one of these when I first started down the hub/disc route but can’t abide aluminium frames, they jar the fck out of my wrists/arse/lower back (I used to have an alu bike).
I was also put off the belt option mainly by the mechanics at Velorution who told me that belts are a gimmick and less efficient than chains (as are shaft drives, the other thing I researched).
I ended up buying a Charge Mixer Alfine and converting it from flat bar to drops and Versa STI shifters – you could easily do the same – you just need these –http://www.sjscycles.co.uk/8-speed-versa-vrs8-sti-levers-for-internal-gear-hubs-prod21918/
and some drop bars, they really are excellent.
p.s. service interval on the 8 speed is 1,500 miles, which is probably a bit premature, I know of one chap who passed 6,000 miles without any servicing at all before I pointed out how cheap/easy it was to do and he swears it made no difference!!
Nick0
My 140 mile/week commuter.
My 140 mile/week commuter. Not sure I can be without it now!http://www.evanscycles.com/products/genesis/day-01-alfine-11-2013-cyclocross-bike-ec043731
Having graduated from this…
http://road.cc/content/classified/145138-charge-mixer-alfine
localsurfer
This is pretty much what I
This is pretty much what I ride, except for the belt drive. Cotic Roadrat with Alfine hub.Really fun bike to ride, loads of fitting points for mudguards, racks, flat bars, discs…. it’s a perfect commuter. I’ve set mine up with a dynamo hub, and it’s brilliant, pretty much maintenance free.
http://cotic.co.uk/product/roadrat/#bike
Scroll down in ‘complete bike specs’ to see the alfine option.
untakenname
Scott sub 10 has a belt drive
Scott sub 10 has a belt drive plus alfine and mudguards but only comes with flat bar.I’ve done a few thousand kilometres commuting through London on it and it’s been fine, I repack my alfine hub every few months to keep it efficient and use atf fluid at £5 a litre instead of shimano’s oil which is £80 per litre!
http://www.scott-sports.com/us/en/products/238387008/Bike-Sub-Speed-10-%28CN%29/
Nick0
Forgot to mention that I’ve
Forgot to mention that I’ve had a fairly good offer that I’m not really in a hurry to accept so let me know if you want to test drive. It’ll suit a rider of 5’7″ to 5’11”Nick0
Chaps this ticks all the
Chaps this ticks all the boxes except the belt. This would be cheap to convert – check out our for yourselves if you’re determined to go down that route, but I guarantee you’ll want chain drive again.Mudmonkey
I’ve been looking at finding
I’ve been looking at finding almost exactly the same spec and the closest I’ve found is the Tout Terrain X-cross. The 2015 is available with Rohloff belt drive. Also the beautiful Shand Stoater FT (but requires remortgaging). Good luckstockfast
How about the Spot Brand
How about the Spot Brand Rallye from Sideways Cycles, http://www.sidewayscycles.com/products/index.php?id=1331&clid=30 ?
I think there are mudguard mounts hidden somewhere. Otherwise the Acme or Ajax fit the bill apart from the flat bars.John_S
Sorry I meant to start by
Sorry I meant to start by saying hi to the original poster edster99 but I looked in the wrong place and got the name wrong.Sorry,
John
John_S
Hi Bakugekiki,
Maybe
Hi Bakugekiki,Maybe something from Tout Terrain might fit the bill although they’re quite expensive and so for a cheaper option perhaps something from VSF might tick most boxes for a commuter.
I think that they are both German brands but when I’ve searched for their bikes their do seem to be places in the UK that sell both brands.
http://www.fahrradmanufaktur.de/en/index.php
Good luck finding the right bike for your commute!
John
gmac101
The set up for removing the
The set up for removing the actuation wire from the Shimano Alfine hub is well thought through, but having a bit of spoke or a 2mm allen key makes it easier. I carry a bottle of foam (Evans do one by Zefal) which gets me back on the road in 5 minutes or so. I then sort the puncture out at home or at lunchtime.Nick0
Only thing that you need to
Only thing that you need to carry in addition to your normal tool kit is indeed a 15mm spanner. I got an SKS multitool that incorporates the spanner, simples.If you buy a bike with track drop outs, you have to de-tension the chain, the vertical drop outs (with eccentric bottom bracket) are much easier as no tension adjustment is needed, I know, I’ve got both.
As for one armed/sided bikes, another gimmick if you ask me!
shutuplegz
Roadside repair of flats is
Roadside repair of flats is an issue with hub gears but only really, as you say, due to the need to take a 15mm spanner of some sort. The problem is no worse with a belt or a chain other than with a chain you are bound to get your hands all oily during the process! The cable is easy to release from the hub and then once you have undone the locknuts either side it is pretty simple. I guess the method of tensioning the belt or chain could make the process slightly more complicated but thankfully (touches wood) I have always gone down the route of avoiding punctures and haven’t yet been caught out mid-ride. I think the reason why the ‘vertical’ dropouts on a sliding dropout or eccentric BB frame are actually about 80degrees is so that you can release the wheel and then re-introduce the chain/belt tension without faffing with the tensioning mechanism just because you have changed the tube/tyre.Cannondale did a BadBoy concept bike a few years ago (they may even have made a few) where they applied their ‘lefty’ fork concept to the rear chainstay and made it one sided. This way you can change a tyre/tube without removing the wheel!
Also, English Cycles, mentioned in your original post, have done a one sided frame and fork design which looks pretty good to me. I’m not sure if any ‘run-of-the-mill’ production bikes have ever done this though!
edster99
I’d never really cottoned on
I’d never really cottoned on to the point about the ‘belt port’. I get that now, but it does raise the question of repairing flats. Most of the bikes I’ve seen dont have a QR. So does that mean carry a big spanner? And can you slip the wheel out around the belt OK without major faffing about? Or do you tend to rely on avoiding punctures as much as possible? I can imagine with the width of the belt, the size of the sprocket, the length or not of the dropouts, it could be a bit fiddly.Nick0
I’ve spoken to the mechanics
I’ve spoken to the mechanics at Velorution, and a couple of commuters who I spotted riding belts, and all of them said that belts were less efficient than chains. I researched the subject extensively before first buying a Charge Mixer (the one for sale in the classifieds), and was so completely sold on versa/alfine/disc braked bikes that a year later I bought an 853 tubed Genesis Day One Alfine (the one in my profile pic) as well. The Genesis replaced the Charge and has been my commuter ever since, doing 140 miles a week.Personally I couldn’t ride those kinds of distances on an aluminium bike, I know that progress has been made making alu frames that are more comfortable, but it is inherently stiff, and will never be as pliant as steel. My two pence worth!
