- This topic has 2 replies, 2 voices, and was last updated 11 years, 9 months ago by .
Started upgrading to Shimano 11 speed. Already have the fd. I know – start at the bottom. I read an 11 speed fd is not compatible with a 10 speed shifter and chainset as the two systems have different pull ratios. Is that true and if so why won’t it work? To my limited logic it seems that if the shifter pulls the correct amount for the chainset then fd should just move the necessary amount. Or am I missing something? Thanks.
