- This topic has 20 replies, 19 voices, and was last updated 11 years, 9 months ago by
Flying Scot.
February 12, 2015 at 3:04 pm #23252
BrokenBootneck
I am looking into getting a camera, but thinking of the pros and cons of where to mount, what’s the general consensus?
Flying Scot
As I ride a unicycle without
As I ride a unicycle without a Helmet I went for the Go Pro tellytubby kit.ianrobo
just got a go pro and no
just got a go pro and no chance on my helmet defo on the bars.bdsl
If you want to make a video
If you want to make a video of yourself cycling you could mount the camera up in the air on a long stick clamped to the back of your seat post, like Colin M. did.
giff77
oozaveared wrote:I don’t wear
oozaveared wrote:I don’t wear a helmet so it’s on the bars.I do use bars..
didn’t always when I was a kid. Not always a good idea. If I saw a kid riding no hands now I’d probably advise them of that. If I was a kid, I’d probably ignore the old fart giving me advice on riding no hands. What the hell would he know. Doesn’t even wear a helmet…
Use bars as well myself, cycling though becomes unadvisable after a while mind 😀
userfriendly
The GoPro is really an
The GoPro is really an unfortunate shape for helmet mounting. Got one of those bullet formfactor cams on my helmet, and I think that still looks a bit daft. May go back to mounting it on the bars again.Also got a rear facing cam mounted on the back of the pannier rack.
(Rear facing as in pointing backwards, not facing my rear.)
PonteD
I tried the camera on the
I tried the camera on the helmet, and it just made it sit lobsided on my head due to the extra weight (plus it made me look like a bit of a tit)I bought a headset top cap that has a gopro attachment and it now sits on the end of the fork steerer tube (just feel the need to avoid confusion by referring to headset, as in “on the bike” as opposed to a “headset” I.e. Something you wear on your head). I feel it better than an up front mount as you can see my bars, this gives a better sense of distance as you have a point of reference close to the lens, plus the actual bars are a little less cluttered.
If you could get a camera with a small remote lens on a wire I might consider sticking that on my lid (a-la-miners lamp stylee with the main gubbins in a box either at the rear of the helmet or somewhere like in my rucksack or on a belt) and I think people who cycle around with GoPro’s stuck on top of their head like a little Blackpool tower just look idiotic (I did mention the word tit earlier didn’t I?).
jacknorell
andyp wrote:What jacknorell
andyp wrote:What jacknorell said, with a tweak.If commuting, put it on the helmet as your awareness of view of other traffic is what you need to capture together with events.
Otherwise, leave it at home. Nobody will be interested in the footage ;)
Unless capturing some seriously interesting racing crashes, please share those!
andyp
Otherwise, leave it at home. Nobody will be interested in the footage 😉
oozaveared
jacknorell
If commuting, put it on the helmet as your awareness of view of other traffic is what you need to capture together with events.Otherwise, yeah, put it wherever.
rhodrigo27
I Ride with a helmet mounted
I Ride with a helmet mounted go pro, first day it felt heavy and cumbersome, now it just feels normal, viewing angle is great, sees what I see, found it better for commuting to have it on the helmet rather than on the bars. what ever suits your needs / wants really!bashthebox
I bar-mounted my GoPro and
I bar-mounted my GoPro and found the road buzz gave it far too much sensor wobble when going at speed. This was the original Hero HD, and they’ve improved the cameras so much now, but I imagine it’ll still be a slight issue. I’ve vaguely thought about getting one of the out front Garmin/GoPro mounts. Still only got the old GoPro though, never getting used.Ants
I tried helmet mounting and
I tried helmet mounting and it was also too heavy and footage is really hard to watch back without feeling ill. K Edge bar mount worked best for me. A small light helmet cam may be preferable for coverage as it would record more of what you were seeing and may be helpful in a accident situation as it may show vehicles behind as well as in front, if this is what you want it for. Perhaps we all need a 360 degree google-cam to be really sure of catching the moment.Wookie
I tried a light on my cycle
I tried a light on my cycle helmet and didn’t like it. I have mounted the one camera as a rear facing and intend to get another to mount on the front of the bike. Probably on one of those out front mounts that take a Garmin on top and a Camera can be fitted underneath.OldRidgeback
Putting the camera on the
Putting the camera on the helmet will give you good footage. But think what the helmet is supposed to do, and bear in mind what happened to Michael Schumacher. -
