- This topic has 73 replies, 40 voices, and was last updated 11 years, 8 months ago by
Mrmiik.
February 5, 2015 at 2:15 pm #23196
ianrobo
We have had the debate with callipers vs discs but in this debate is there really any debate ?
GCN have just published a vid from Dubai which shows 90% of the pro’s are now on electronics and if not for the cost I would imagine most of us amateurs would be as well. Since going to EPS and comparing it to the mech of chorus (ok got record EPS so difficult to quite compare like to like) then the difference in shifting is light years.
Is there anyone who would not want to use electronic (be it EPS, DI2 ) over mech if we ignore the cost of it ?
Initialised
Here’s an idea to stop us
Here’s an idea to stop us from having to worry about battery life and power consumption. Charge the system’s battery from solar and with a small dynamo on the top jockey wheel, run a cable down the drive side chainstay to power the front derailer.ianrobo
as I have the same as you a
as I have the same as you a mech chorus and record EPS I can compare the two and really is half and cheese for me …As for charging so far done about 500km on the EPS and recharged the once
therevokid
ianrobo wrote: …
but now itianrobo wrote:…
but now it is easier esp on a climb to get out of it.is it ??? I get caught in the wrong gear on my mechanical chorus, I push the paddle,
it changes down, i get out of the wrong gear … how does electronic make it
easier ??Do you keep your “best” electronic bike charged up and ready for the first of
the “oh nice day … i’ll take the other bike” days ?And no one in their right mind will say that the electronic front mechs are not
hideous !!!Think I shall remain luddite mechanical … 🙂
ianrobo
Simon E wrote:
To the OP:Simon E wrote:
To the OP: I’ve not tried electronic shifting so I don’t know what it’s like. By all accounts it’s great. It’s not automated, the rider still chooses which gear and when to shift, it merely refines the process of moving the mechanism across, which seems similar to the benefits that indexing brought us.exactly like today I can still get caught in the wrong gear, thats my fault but now it is easier esp on a climb to get out of it.
Like anything technology moves on and people will adapt. I still as explained in another thread would not want disc brakes but that is simply because I believe personally not that much benefit (as compared to electronic gearing).
abudhabiChris wrote:when I
abudhabiChris wrote:when I look at someone riding EPS or Di2 I see a cheat.By your reasoning surely any bike with more than one (fixed) gear is cheating too 😕
My only (possibly unfounded) semi-Luddite fear is that if it went wrong it could be expensive to fix. I feel the same way about electronic gizmos built into modern cars.
I wouldn’t set much store by what sponsored riders are told to use by the manufacturer. 90% or more of the pro peloton ride tubular tyres; in the past most of them used EPO and blood bags, and before that amphetamine cocktails etc, but that doesn’t mean that any of those things would be a good choice for me. If you like it then enjoy it 🙂
ianrobo
fukawitribe
fukawitribe wrote:abudhabiChris wrote:A bike is a human powered vehicle. Once you use external power to assist part of the drive train of the bike it is no longer completely human powered.You’ve made that up – a bicycle is two wheeled vehicle by definition, nothing more.
abudhabiChris wrote:Anyone riding electronic gears is no longer riding a bike. Go ahead, it’s your choice, but when I look at someone riding EPS or Di2 I see a cheat.😀 I presume you don’t use ‘cheat’ in the sense of ‘avoid using luck or skill’. As you say, it’s a choice and imposing your own definition of ‘bike’ doesn’t make it inherently a good or bad one. Why not enjoy what you want, and let others do the same.
well I am guessing that under this definition anything made of carbon is ‘cheating’ .
All electronic does IMHO is to make shifting gears easier for me and they are more efficient but so are tyres, wheels, everything.
fukawitribe
DaSy wrote:I understand the
DaSy wrote:I understand the necessity to change under heavy load at times, but don’t think it should be thought of as a normal thing to do..completely agree.
DaSy wrote:I can’t imagine ever knowing a road so well that I knew in advance what gear to be in.Seriously ?
DaSy wrote:I tend to change as required, I just do it before I get myself into the situation where it’s under heavy loadAs I said, not always possible short of some sort of prescience super-power but I get your gist.
fukawitribe
crikey
Quote:Go ahead, it’s your
Go ahead, it’s your choice, but when I look at someone riding EPS or Di2 I see a cheat.Sent by carrier pigeon, I hope, you electrical correspondent slacker! :))
Richard1982
“when I look at someone
“when I look at someone riding EPS or Di2 I see a cheat.”Bit harsh abudhabiChris! LOL.
Before you say anything I use mechanical 😛KirinChris
A bike is a human powered vehicle. Once you use external power to assist part of the drive train of the bike it is no longer completely human powered.It’s not the same as having a power meter which is simply measuring your output, or a computer, or aero wheels or anything like that. Saving energy and measuring energy are not the same as contributing energy.
For that simple reason I will not ride electronic gears. I have had the option at very low cost on a team bike and turned it down.
If you back off the power for
If you back off the power for the split second as you change under load, you reduce the damage you cause the drivetrain, this is easy to feel on mechanical as it is a direct feedback, but less so with electronic as you are isolated, and I think not feeling the connection may lead many to think it’s okay to do with impunity, and judging by the comments above many think that as it does it easily, it is okay to do.
I understand the necessity to change under heavy load at times, but don’t think it should be thought of as a normal thing to do, unless you are happy to change chains and cassettes regularly.
I can’t imagine ever knowing a road so well that I knew in advance what gear to be in. I tend to change as required, I just do it before I get myself into the situation where it’s under heavy load
fukawitribe
DaSy wrote:The argument that
DaSy wrote:The argument that it changes easier under load uphill seems to run counter to all the wisdom that I was taught as a novice rider, that you never change gear under heavy load, get your gear selection right at the start of the hill, and always take the load off as you change, should you have to.
The fact that electronic shifting is isolating you from how much effort it is taking to drag the chain across rings and sprockets, does not mean that it is not doing the same damage to your drive-train that it does to a mechanical group. It’s bad form in my opinion.While it might be bad form, the argument about whether it does change better under load (of any sort) is a separate one to whether one should be doing that. There is also the point that whilst I imagine most people would prefer not to do that, in practice things don’t always work out that way – certainly i’ve been caught out be gradients that change suddenly and are not apparent / visible, had wheel slip, chain jump (my fault) and so on… it’s just not always possible to Do The Right Thing. If you’re just riding on well-known roads then I can see the point, but where is the fun in that ? 😉
I’ve also built quite a few
I’ve also built quite a few EPS and Di2 bikes for people, and it is a nice system that works well. I have seen some weird problems that have been ride stoppers for the owners, that would have been easy fixes for the equivalent mechanical version.The argument that it changes easier under load uphill seems to run counter to all the wisdom that I was taught as a novice rider, that you never change gear under heavy load, get your gear selection right at the start of the hill, and always take the load off as you change, should you have to.
The fact that electronic shifting is isolating you from how much effort it is taking to drag the chain across rings and sprockets, does not mean that it is not doing the same damage to your drive-train that it does to a mechanical group. It’s bad form in my opinion.I still ride 7800 despite having access to Di2 at trade prices, and if I were to upgrade it would be to 9000 mechanical, as that really does seem to be the best a mechanical group is liable to get, unlike 7900 which was a backward step.
I really do doubt the extra speed of electronic shifting argument, surely there will be a minute drop in power as the chain passes between sprockets, so saying that more shifting equals more speed seems somewhat specious.
danjoyce
In response to the OP: I
In response to the OP: I don’t want electronic gears, thanks. In fairness, I’ve only tried it at shows; the front derailleur made a wicked whirring noise that felt very 21st century! I can see that it might offer a marginal advantage if you’re say, a road racer and want to get the jump on someone in a sprint. (Although even then, changing your cadence can be quicker than changing gear.) But I don’t really want more batteries on my bike. I like that my bike is fully serviceable and fixable by me. And I like that it’s wholly human powered. If you want to go faster through Strava segments, meanwhile, you need to train harder and reduce you and your bike’s combined air resistance, rolling resistance, and weight; electronic shifters will not do those things. -
