- This topic has 14 replies, 9 voices, and was last updated 11 years, 7 months ago by
mcjsska.
February 4, 2015 at 1:44 pm #23182
mcjsska
Came across a very good offer on a De Rosa Idol. I know it’s fine for absorbing road buzz & bumps – but how about the geometry for a 50 yr old back wanting to do fast-ish sportives/endurance?
Any guidance appreciated..
Kevin
mcjsska
Thanks to all for the various
Thanks to all for the various comments, even the ‘ clever’ quotes.Kevin
Sniffer
As a man in my mid 40s who
As a man in my mid 40s who does the odd sportive I thought that the sportive bikes might have been for me. That was until I had a bike fit last winter. Apparently my (slightly) proportionaly longer back and shorter legs coupled with reasonable flexibility I was encouraged towards more race orientated geometries even if I don’t race. It was the right advice.So now I know I am more Tarmac than Roubaix or Supersix than Synapse. ‘Other bike brands are available’.
So if you are spending the kind of money you are thinking about it might be worth getting a bike fit. The guy that did mine gave me a recomended stack and reach which you may find narrows the options and helps inform decisions if nothing else.
Cyclist
Fitness and flexibility…
Fitness and flexibility…bfslxo
I’m 14 months of my fiftieth
I’m 14 months of my fiftieth & have been riding a R838 for two years,
Whilst it’s a little stiff it handles supremely & is as fast as you can make it ever hope to go.
Will I ever race it, never, I don’t race never have never will & don’t care to either, simply is not my thing.Last year amongst others I done my two longest sportive’ s to date – 144 miles & 132 miles
I cycled a week in Tenerife with one days climbing @ 12,000 ft. most days over 8000 ft.
all on the De Rosa R838 which is apparently a pure racers bike!Whilst I may have got a tired back some of those days, I’d defy anyone not to have the same no matter what bike they ride
Quite simply my De Rosa is the most comfortable & best fitting bike (for my frame shape/size) I have ever owned & I dread
the day I need to change her outCXR94Di2
My bike has quick release
My bike has quick release front and rear with hydraulic disc brakes. I weigh 95kg and don’t notice flex. But then I have a cyclocross frame bike so might be more rigidmcjsska
Thanks for the ongoing tips &
Thanks for the ongoing tips & advice.An extra question. The Idol is QR rather than bolt through – any thoughts on, or better still experience with, the stiffness of the Idol fork with discs and QR? I note the Road CC review of the Bianchi Infinito CV Disc (which also opts for QR) considers the forks insufficiently stiff. As a tall & heavyish (90kg) rider who’ll spend a lot of time on hills too much flex is a concern.
Thanks in advance for any views
Kevin
Sub4
The DeRosa Idol is beautiful.
The DeRosa Idol is beautiful. Quite long top tubes, so racy geometries. Unless you’ve got back inflexibility/injury history, you should be fine on one of these. Plenty of steerer tube to play with! There are retailers around, although the online database is rarely accurate. Contact I-ride (the importer) for accurate info.brummie_biker
Kevin – where are you based?
Kevin – where are you based? Sutton Runner in Sutton Coldfield stock a small range of De Rosas and their bike mechanic Al is a magician.CXR94Di2
BBB sell stem risers and a
BBB sell stem risers and a selection of steep angle brackets. Look at wiggle. You can make a racer into a comfy tourer with £25 outlay.Welsh boy
I wouldnt worry about it
I wouldnt worry about it being too twitchy, i would rather have a bike that responds (especially when i am tired) than one which is a little bit sluggish, it might just be the difference between hitting a pothole/rider in front and missing it. Also, raising the bars has the effect of shortening the reach slightly which may help your 50 year old back a little!mcjsska
Thanks of the advice and
Thanks of the advice and particularly the issue of adding spacers etc. I have previously rung around a geographically wide set of dealers who, according to the importers website, sell the bikes, but none keep them in as a stock item. If anyone knows of a stockist I’d be prepared to travel – within reason.Kevin
pablo
Try one! If your worried
Try one! If your worried about if you fit the bike because of age/fitness that’s the only way of telling or by comparing any of your current bike geometry to your new purchase. Adding spacers and flipping bars is a solution but it will potentially affect the handling of the bike. sitting you upright shifts your weight reward which can get interesting on descents I know this from experiencemcjsska
Thanks for that – I’ve done
Thanks for that – I’ve done something similar on my old Tricross. I see this raises the bars, but having not ridden a modern full-on race machine I thought their shorter wheel length typically made them a bit twitchy?Kevin
Welsh boy
Bang a few spacers under your
Bang a few spacers under your stem, flip the stem so it points up or at the very worst buy a stem with slightly more lift and you have a sportive bike. There is no reason whatsoever why a race bike cant be used for sportives (apart from the marketing man’s power of persuasion). -
