- This topic has 8 replies, 5 voices, and was last updated 11 years, 9 months ago by .
Okay, this should be a simple question seeking a simple answer (though not one simple enough that Google has yet solved):
I have a track bike with a fix/fix rear wheel. One side has – what I believe – is standard track threading; two concentric cylinders protruding from the wheel, the first with normal clockwise threading to accept the cog, and the second, smaller cylinder protruding from the first, with anticlockwise threading to accept the lockring.
I’d like to install a cog on the other side to give the bike as much flexibility as a fixed gear can get. However, that side seems to be missing second, smaller, anticlockwise-threaded lockring cylinder. So, it’s just a single, clockwise-threaded, larger cylinder, meaning it can accept a cog, but without the security of a lockring.
So my question is, what am I meant to do with this design, and what purpose does it serve? I’m sorry if it’s an embarrassingly ignorant question; I’m embarrassingly ignorant and am grovelling for advice.
Thank you!
