Brake blocks for Campy mirage brakes
  • #23047
    gallowayalex
    I’m trying to work out which alternative brake blocks would be compatible with my campag mirage brakes, but struggling a bit. At the moment I have the campagnolo brake blocks (NB: they’re the solid blocks rather than the brake shoes with inserts. These ones I think: http://www.wiggle.co.uk/campagnolo-veloce-vl600-pack-of-4-brake-blocks/), but would like to find a better alternative (e.g. Koolstop, Swissstop).
    Can anyone recommend any that would be compatible?
  • #827815
    alun
    I’ve found these to be just
    I’ve found these to be just as good as OE Centaur pads. If you get separate holder and pads this this you’ll only need the pads next time. http://www.discobrakes.com/?s=0&t=2&c=38&p=139&tb=001
    #827813
    mike the bike
    Campag’ blocks, at least
    Campag’ blocks, at least those with the cartridge and separate rubber, are, in my humble opinion, the best you can buy.
    #827811
    lolol
    I always found the Campag
    I always found the Campag blocks work very well, but you can buy Swiss Stop and others as blocks with holders. Dont skimp on cheapy blocks, I bought some Lifeline blocks, they were terrible, picked up lots of grindy grit, felt like £5 worth of rim going every time you braked, switched to Koolstop, so much better
