- This topic has 8 replies, 7 voices, and was last updated 11 years, 10 months ago by .
I’m wondering if anyone else has experienced this and whether it is normal. I regularly check my chain for wear, but usually just measure at random places along its length.
Tonight I’ve just measured my chain and it’s still shows as being fine when I measure across any length of chain. However, out of curiosity I made sure I measured across the split link (SRAM powerlink?) and the chain wear indicator just dropped straight through showing it needs replacing. I’m assuming the link is at fault and not the rest of the chain.
Is it normal to expect your chain to wear at the split link before anywhere else? I( was under the impression that chains wore uniformally).
Alternatively, do you think the split link is on its way out? I’ve ordered a couple of replacement links so it will be replaced in the next few days, but don’t like the idea of replacing split links every couple of hundred miles.
