- This topic has 14 replies, 12 voices, and was last updated 11 years, 10 months ago by
parksey.
December 31, 2014 at 9:43 pm #22939
Nat Jas Moe
I’m after a route planner to help me achieve my goal of 12 metric centuries this year.
I’m after some random routes from where I live that will offer a varied ride each time I head out.Many thanks in anticipation.
parksey
nigsbrown wrote:Worked out
nigsbrown wrote:Worked out how to get the make a route to function near me. I had to set a via point and then it worked. Shame there isn’t an avoid major roads feature, as alot of the routes that it cam up with had turns across traffic on dual carriageways. :SThat’s odd, as there used to be, although it was still a little hit and miss. I see now that they’ve replaced it with a facility to avoid certain roads by selecting them on the map.
Seems to be a backward step to me, if you’re plotting routes which may take you through unfamiliar areas, how would you know in advance that the roads wouldn’t be suitable, unless you “ride” the entire route in Streetview first?!
nigsbrown
Worked out how to get the make a route to function near me. I had to set a via point and then it worked. Shame there isn’t an avoid major roads feature, as alot of the routes that it cam up with had turns across traffic on dual carriageways. :SPonteD
+1 for RideWithGPS, not only
+1 for RideWithGPS, not only can you make your own routes up, but you can search for routes that others have shared and take your pick (you can filter by location and length as well).Alternatively the Garmin Edge Touring apparently has a feature where you tell it how far you want to go and it will make up several routes for you on the spot. Don’t own one so can’t comment on how good it is, but would love an app/website that could do this for you and then give you a gpx file to download.
Alternatively you could throw your money at a few sportives or Audax’s (thus paying someone to do all the hard work for you).
nigsbrown
It’s a shame as plotaroute
It’s a shame as plotaroute looks like a nice interface but the make a route doesn’t work for my location.bdsl
I hadn’t seen plotaroute.com
I hadn’t seen plotaroute.com before, but it looks really good. I might try routes from that ‘make me a route’ function between home and work.
Nat Jas Moe
Thanks to all for your
Thanks to all for your suggestions and remarks. Will try some of these out. Cheers to you all.parksey
http://www.plotaroute.com is worth a
http://www.plotaroute.com is worth a look.On first glance it appears a normal mapping facility, but if you use the “make me a route” function then it’ll create 10 random routes for you based on a given start/finish point and how far you want to ride.
You might want to use the in-built Streetview functionality just to double-check whether some of the roads are suitable, but it’s a good start and it’s easy to modify the route if you need to.
Routes can then be exported in various formats to use on whatever device you’ve got strapped to the bars.
RidewithGPS.
Alternately use
RidewithGPS.
Alternately use Google Maps and plot a route from one end of your road to the other. Then drag the line outwards to create a loop of the desired length.redmeat
Bike Hike.
Bike Hike.
philly
I’ve plotted routes with
I’ve plotted routes with ridewithgps and Strava to name just a few. For me, exporting courses out of Strava to use with a Garmin 800 works best, assuming you want turn by turn directions… So far I’ve found this the most reliable and you don’t need Strava premium!pablo
I use strava search to find
I use strava search to find local routes other people have done that I haven’t done before I then download them and us gpsies.com to draw over them with any mods I want to make. Gpsies will also add route guidance but not as good as ridewithgps. If ridewithgps would add turn-by-turn to imported routes that would be killer. I then load the routes on my garmin.glynr36
use strava, then if you have
use strava, then if you have the app on your phone the route is there with you.
Also gives you a rough guess of duration from your average speed in the last 4 weeks.massspike
When planning routes on
When planning routes on unfamiliar roads, I use Google StreetView in conjunction with MapMyRide (which used to have the absolute best route mapper — since copied or licensed by others). StreetView gives you a good idea as to the road surface (I ride lots of gravel/dirt roads), lets you see if there are paved shoulders or bike lanes, and even how busy the road is (judged by how many cars are in the images).If I am looking to find/add the best climbs I use Strava’s search by categorized climb feature. Note: Strava’s beta version route mapper looks pretty good so I might drop MMR for it.
I’ve also been experimenting with Strava’s Heat Map to identify the popular road sections — I am not sure if it indicates quality over quantity yet.
I would love to see these combined in to a single tool (hint)
therevokid
i use ridewithgps … plot
i use ridewithgps … plot away, export to the garmin and go ride … 🙂 -
