- This topic has 30 replies, 14 voices, and was last updated 11 years, 8 months ago by .
This is not a dig at the product as I think it’s very good. This is merely a head’s up to others wanting to get into power.
I went for Powertap because it was pretty much the cheapest and simplest way into a power meter. So far it’s performance has been exemplary, software update and battery change not an issue.
The problem now though is that one simply wont do.
Eying up some carbon wheels for the spring when I hope to be moving along swiftly enough that I wont be ‘all the gear, no idea’. That means buying another one (but I knew that would happen).Riding on the trainer flat spots the tyre (is that only me?) which I didn’t I foresee. Last weekend punctured rear though the flat spot. New winter tyres gone on today.
So to not flat spot the tyre again means swapping tyres every turbo session – or buying another Powertap wheel just for the trainer.So, to be in a sensible situation (unless you go with riding the flat spot on the road) you need a minimum of two, or three if you want two sets of road wheels.
That adds up to circa £1800, although not in one go, but obviously some other systems would have been cheaper in the long run and not restrict wheel options – and that’s the head’s up really. Yes I did read up and research and in the end I wouldn’t have done differently as I was so keen to get into power. Others may not be so rash. I imagined I’d end up needing two – but three may have tipped the balance and convinced me otherwise.
I always knew I’d need two but I doubt I’m a one off case and most PT users may end up needing three.
I’m not complaining so please don’t pick holes – just putting what I’ve found into the power meter discussion pot.I imagine I’ll move away from PT rather than buy the second and third.
