- This topic has 17 replies, 15 voices, and was last updated 12 years ago by
Sidi 700c.
November 20, 2014 at 11:28 am #22754
Malhone
Morning,
Wonder if anyone could suggest a good front light, the amount of options out there is a bit bewildering…
Needs to be :
Suitable for road/ country path use
Easily clip on and offable, no external batteries
Maybe between 600-800 lumens
I like the alloy body type ones too, good and toughAlso would also appreciate advice on bright rear lights
Thanks in advance for all advice
Matt
Sidi 700c
Are mods deleting posts here?
Are mods deleting posts here? I remember giving a very negative report on the Moon Comets that i think was in this thread. Nowhere to be found now and there are not that many people that comment here judging by how slow the forum topics recycle.Malhone
Morning all,
Many thanks for
Morning all,Many thanks for all the input and suggestions.
As per the effusive second poster, I’ve found some a Lezyne Deca Drive front and Micro Drive rear on sale for 46% off… (Sport Pursuit if anyone needs some lights).
The Deca drive does seem extremely bright, so I’ll run it in eco mode for now.
Thanks all!!
Mattredmeat
KiwiMike wrote:redmeat
KiwiMike wrote:redmeat wrote:Lezyne Power Drive XL/endthreadThe XL’s 475 Lumens isn’t really bright enough for more than about 10MPH, in my experience. Other than that, crackingly good light.
Regularly doing night rides 18mph+. No problem.
KiwiMike
Gareth W-R wrote:Get yourself
Gareth W-R wrote:Get yourself on eBay, get a solar storm x2 ( just eBay bike lights and you will get a selection ) have been using one for months now, much brighter than light sets costing 10x the £20 you will spend. I was using a topeak hp 5w before which was good but cost £230 and does not stack up light wise. Run time is not as good but as long as your night rides are not too long you can get 3-4 hours out of the solar storm ones.Another +1 for the SolarStorm X2 at around £25. Been my go-to fast night riding light for a year now. Tons of light, good spread, small-ish, battery lasts well over 2+ hrs if you cycle between high and low for descending/climbing.
Nothing comes close for the money. Nothing.
Daveyraveygravey
OP, I would really recommend
OP, I would really recommend two lights front and rear; you can never be 100% sure if you have just one that it isn’t going to conk out on you, for whatever reason.Can I ask why you don’t like the battery pack ones? I have a couple of the cheap Chinese ones from Ebay and they are brilliant, I really cannot understand why anyone would pay more.
bendertherobot
I’ve taken a different
I’ve taken a different approach this year. Where, before, I did bright, I now do Smart.So, at the front, a Philips Saferide 80 and See Sense 190. Very good combo.
At the rear a See Sense 155 lumen (which is just excellent) and two red fibre flares on the seatubes, both on solid.
Finally a flashing green fibre flare on my rucksack just for that bit more noticeability.
My perception is that I feel safter than I did running a huge lumen magichine and piercing knog blinder
Pierre
oddbydefault wrote:If you
oddbydefault wrote:If you want a truly beastly rear light, get the Moon Shield.Retina burning 60 lumens, fantastic side-visibility, mini USB rechargeable, and insane strobe mode for when you *really* want to be seen (not recommended for club runs – even low power is too bright).
True that – it’s an amazing little light but is almost offensively bright. The little rubber strap fits nicely round the back vents of my Kask Mojito helmet, so if I’m going out for a ride alone I’ll usually put it on, but even on low power mode it’s plenty bright enough to make sure I’m seen from way back. Drivers may honk at me but at least that means they’ve seen me. I’ve never dared use it on high-power mode, it would just p’ss people off! (though I wonder if I could deploy it when racing to stop someone sitting on my back wheel…? ; )
oddbydefault
It clips on to a bracket with a sturdy rubber strap which fits almost any seatpost, and even seatstays. The bracket is easily adjustable, so you can angle it however you like.
http://www.wiggle.co.uk/moon-shield-60-rechargeable-rear-light/
If you’re after a front light too, the Shield can be bought in a package with the X-Power 300 http://www.wiggle.co.uk/moon-x-power-330-front-and-shield-rear-light-set/. It’s a cracking light, even at ‘only’ 300 lumens. I mount it in conjunction with a Lezyne Super Drive XL (which gets a run for its 575 lumens – it’s definitely not twice as bright) on my commute which is a mix of lit and unlit roads, or sometimes pitch black cyclepath. Only switch on both in the totally unlit bits (because why not), and when I fancy looking more like a car.
Gareth W-R
KiwiMike
Freddy56
I am 3 weeks into my
I am 3 weeks into my see.sense. due to the city commute and too many near misses I do feel it has the extra edge for safety. One charge is lasting me 10 hours which for me is a full week. Would go for the 120lumen as I think the 200 one I bought is too bright for on coming traffic.oldstrath
Paul_C wrote:Philips Saferide
Paul_C wrote:Philips Saferide 80has a bright dipped beam which does not dazzle and reaches out quite well. Almost all the light goes down onto the road.
rechargeable, but in a pinch, can take ordinary AA batteries if you have the right allen key.
http://www.philips.co.uk/c-p/BF48L20BBLX1/led-bike-lights-80-lux-battery-driven-black-aluminium
I’ve also got a Philips Saferide rear light which doesn’t dazzle either and a Lezyne Microdrive rear light.
If you’re looking for a Saferide you might struggle – Rose Bikes appear to have some http://www.rosebikes.co.uk/article/philips-saferide-80-led-bike-light-battery-front-light/aid:642260
Also be aware that the run time on high is short – 2 hours claimed, realistically about 90 minutes even with good batteries. On the other hand it probably is about the best of the battery-driven dipped beam headlights for dark road use. More ‘sociable’ than high- lumen torches. Whether that’s actually the same as ‘better’ is a harder question.
Reg Molehusband
I have a Petzl Tikka XP2 head
I have a Petzl Tikka XP2 head torch which has the usual steady/flashing modes. 70 Lumens and a wide reach of 40 metres. Highly weather resistant and robust. Rather than buy an expensive more powerful cycle lamp, which would probably blind oncoming motorists, I’ve adapted the Petzl to attach to the handlebars. Petzl do an Adapt Kit which has enabled me to clip the light onto a small bracket that I’ve made. The rear light is a B’TWIN VIOO Clip 300 USB which I bought from Decathlon for £8.50. It’s bright enough to do the job and in flash mode can last up to 9 hours. I’ve got mine clipped to the back of the saddle bag.Paul_C
Philips Saferide 80
has a
