Bent Link – SRAM pc1031 – Options?
  • This topic has 6 replies, 6 voices, and was last updated 12 years ago by backflipbedlem.
  • #22740
    backflipbedlem
    Hey all,
    I have a SRAM pc1031 10 speed chain.
    I recently had a crash which bent my mech hanger, which then snapped pulling the whole derailleur into the wheel, and bending the mech to pieces.
    So whilst waiting for my replacement mech I thought I’d give my chain a clean.
    So I pushed a pin out of the chain, and proceeded to give it a good clean.
    I then discovered that one of the chain links was bent, and that I also had a powerlink meaning I didnt have to push a pin out.
    I’m now finding it difficult to source a spare link or a relevant pin.
    What are my options? Can i replace a single link? or when u have a bent link do you just have to replace the whole chain?
    I’ve found a new chain for £13.99 inc postage, but want to know if I can fix it for cheaper, as there is nothing wrong with the rest of it. And it is nice and shiny clean again! lol
    Any help greatly appreciated!
    Cheers,
    Lee
  • #821069
    backflipbedlem
    The _Kaner wrote:…and if
    The _Kaner wrote:
    …and if you have a bent inner plate…unless you have spare links, to cannibalise…you will need a new chain
    That is a very good point! And one that would of defo tripped me up! And cost me a few quid!
    New chain it is then!
    Cheers for all the help guys!
    #821067
    The _Kaner
    Gkam84 wrote:Can you not just
    Gkam84 wrote:
    Can you not just stick in another powerlink to replace the broken one?
    There is no issue with having multiple powerlinks in a chain. Infact, you could make a whole chain from powerlinks and it would work fine
    Technically, you couldn’t make a ‘whole’ chain from power links…
    You could replace all ‘outer plate’ parts of a chain with power (missing) links…but not the inner plate parts…and if you have a bent inner plate…unless you have spare links, to cannibalise…you will need a new chain
    #821065
    Flying Scot
    I wouldn’t risk it, replace
    I wouldn’t risk it, replace the chain, there may be other damage you haven’t noticed as the drive line got chewed.
    #821063
    CXR94Di2
    Just sling it, better still
    Just sling it, better still weigh it in. You’re going to risk damage to the new mechanism for £13!
    #821061
    massspike
    I always save the excess
    I always save the excess lengths of chain just in case I need to replace a damaged link or two (requires a chain breaker). If you didn’t maybe one of your mates did or possibly a friendly LBS might give you one. A few links of any SRAM 10-speed would do.
    You might also want to check the wear level on your old chain first. It could well be worn enough to justify that new chain. (Just lay a 12″ ruler over the chain, it should line up with the end of a link, if it has stretched more than 1/8″ it is shot)
    #821059
    Gkam84
