- This topic has 53 replies, 37 voices, and was last updated 11 years, 12 months ago by
cavasta.
October 31, 2014 at 6:16 am #22661
Kalam
Hi all, This is my 2nd post so apologies if this has been covered before. Need a proper plan to reduce weight also increase my Road Cycling performance. My weight around 242 Ibs and height is 5’7″. So i need a total training plan for both running & cycling which help to decrease weight & improve my road cycling performance. my cycling average speed is around 30 km/hr when I train but i can’t continue speeding up in longer distance as my friends do. if i do my avg pace decreased to 24-25 km/hr. so i fall behind. So all I need a proper training plan to increase my pace along with reducing my weight.
Any advice gratefully received. Thanks in advance.
nickobec
There are two parts to the
There are two parts to the OPs question:
1: Improve performance
2: Lose weightEverybody is answering 2, just assuming it will fix 1.
My first question is where do you need to improved your performance most:
1 Sprints up to 15 seconds
2 Short hard 2 to 5 minute efforts
3 Medium 10 to 30 minute efforts
4 Longer hour plus effortsBecause knowing where you want to improve impacts on diet choice and training.
You need to understand how your body works, how it fuels itself and how you monitor it. ie buy a heart rate monitor (or power meter)
If you need to improve in areas 1 to 3, you can not cut carbs out your diet, you can not afford to go into significant calorie deficit (ie more than 500 calories a day out more than in) As you need to train at that level, get your heart rate monitor, learn about zones and do 15 second Zone 7 interval for sprinting, 5 minute Zone 6 VO2max intervals for 5 minute or so efforts and 20 minute threshold sessions at zone 5 for longer.
If you want to get strong rider over an hour plus , then is long zone 3 rides with burn fat more than carbs, so you can afford significant (ie 500 calorie plus deficient diets).
So set your goals, where do you need to improve your performance, how do I need to fule my body. How do I decrease my energy intake sensibly.
Paul_C
LCHF, worked for me, dropped
LCHF, worked for me, dropped from 17 1/2 stone to 13 stone in just 4 months…Kalam
Thanks Everyone for
Thanks Everyone for suggestion. Specially to Simon E.pants
eat less, ride more.
/thread
eat less, ride more./thread
cavasta
Read this book and do what it
Read this book and do what it says:PonteD
I can only echo what people
I can only echo what people are saying, and watch your food, rather than the exercise. My commute burns off about 1400calories, so eating at a deficit is fairly easy but I still have to watch what I eat.I was 240lbs a few months ago, since then I’ve lost 25lbs just by making sure I don’t overeat. What I have noticed is that avoiding foods like bread and pastry results in quicker weight loss, I now try and avoid these as much as possible, so little changes like cutting out sandwiches for lunch and going for salads instead has helped. Also look at portion sizes, you may find that eating a normal sized portion will make a big difference, I have a habit of piling food onto my plate and eating way too much as a result.
AAN
I’ve amazed myself and others
I’ve amazed myself and others by going from 252lbs to 190lbs in a year of steady loss. I’m 5’10”. I’d tried all kinds of ways to lose weight and become fitter and be able to ride my bikes with more comfort and faster!
I hold no fancy opinions on the subject but can tell you what worked for me.
I downloaded and read the free PDF of The Hackers Diet. It’s a simple exposition of the obvious fact that weight loss is achieved by burning more calories than are consumed.
I splashed out a hundred quid for a set of Aria wifi scales so I could have an automatic and reliable record of my weight.
The analysis of the numbers and their display is easily sorted with the free Trend Weight.
May not work for you, but this combination was just what I needed.
I’m so delighted with being able to ride much further and a bit faster than before.
Apart from anything else that food-baby makes tucking down over the bars uncomfortable.
Happy to elaborate on all this or support you in any way. Good luck!
don simon fbpe
I started to look at the food
I started to look at the food I was consuming as a whole and began to make changes. The biggest being a move away from rice and pasta to lentils and beans and building up a new diet around this. I cut sugar, but never really had a sweet tooth anyway and do a whole lot of cooking rather that buying processed foods.
The fat just dropped off in a way that people could see the weight loss on a week to week basis.
After changing my diet I found this ( https://docs.google.com/file/d/0Bw_T87IBJ5crZTE0YmU1OTMtOGM0Yy00MTk5LTk1OGUtMjY5NzY1NDk4YWNi/edit?hl=en&authkey=CNeXx-wG ) which reinforced what I was doing as being OK. 5 years later and I’m still eating plenty as it’s not a calorie restrictive diet and the weight is still off.howdenbiker
‘Or alternatively, just try
‘Or alternatively, just try to eat healthily and ride your bike a lot (or take other forms of exercise). Without recommending any specific ‘alternative diets’ to stick to, it should be possible to identify the less healthy things in your existing diet, and cut down on them, or cut them out completely.’I totally agree with the above, I restarted cycling in September, about 300 miles a month, some commuting some weekend riding, no other exercise. I don’t do high pressure training, just cycle at a rate that I feel comfortable with that raises the pulse rate but doesn’t see me arrive at work covered in sweat!
I’ve cut down on food intake and started eating sensibly. Main change is dropping sandwiches and snacks at work for a big salad with tuna or chicken.
Weight lost is just over a stone in 1 month, I’m 5′ 9″ and started off at 210lb.
I’m not sure what you mean by
I’m not sure what you mean by “a proper plan” but we can only offer general advice and opinions based on experience. Here’s mine:1. Eat less processed crap – biscuits, cakes, pies, sweets, fizzy drinks etc etc – and start eating more healthy, unprocessed (preferably raw) food. Gradually reduce portion sizes for starchy carbs like bread, pasta and potatoes. Just like the results of physical training, appetite control and retraining your mind’s expectations takes time. This is a lifestyle change, not a ‘diet’.
2. Ride frequently. Don’t batter yourself but ride at a sustainable pace, which may mean different company or solo if your mates won’t slow down. Keep it simple, do a variety of short, energetic rides and longer, steadier ones. No food unless longer than 2 hours, and no energy drinks, only water. If doing a long, steady ride in the morning eat nothing beforehand, take some dried fruit or a cereal bar or two to have after an hour or so. Once your body adapts you’ll be surprised at just how far you can go with no brekkie.
It may help to track your rides. You should see a gradual improvement on the same routes over time. Set realistic targets, both short and longer term, but make sure you have to work to achieve them.
Remember that Rome wasn’t built in a day. However, everyone can achieve great things if they put their mind to it.
If you want more specific information then you should either buy a training manual or seek out a good coach.
CXR94Di2
Eat less, exercise more. Be
Eat less, exercise more. Be realistic and don’t starve yourself or over train. Given enough time you will lose weight. Just try to remember how long it took you to put those extra pounds on. It takes time to shed them. Good luckredmeat
Eat less, move more.
Eat less, move more.Quince
Take the high carb, low
Take the high carb, low protein, low fat diet on Mondays, then switch to a low carb, high fat, high protein diet on Tuesdays and Wednesdays, followed by a day of fasting on Friday, and then go vegetarian on Saturday and eat nothing but roadkill on Sunday.Or alternatively, just try to eat healthily and ride your bike a lot (or take other forms of exercise). Without recommending any specific ‘alternative diets’ to stick to, it should be possible to identify the less healthy things in your existing diet, and cut down on them, or cut them out completely.
Vegetables, fruits, nuts, oats, etc. – the kind of stuff that’s managed to survive the constant fluctuations in what if considered ‘healthy’ – probably ARE actually quite good for you. You might mainly be able to improve your diet, however, by simply eating less of the things that are generally accepted to be ‘not so good for you’. I find it’s easier to gorge on biscuits, cakes etc. than to consume the equivalent number of calories in less energy dense, less processed foods.
Of course, given that we don’t know anything about your diet, it’s hard to give any specific advice, but I’ll have a vague stab:
Many people consume several cups of coffee/tea each day, each with several spoons of sugar. Un-sugaring those drinks would add up. Or… down.
Most pre-packaged food tends to contain a lot of fat/sugar/salt, so cooking more of your own food could give you a better feel for that’s going into it.
Also; White bread -> Wholemeal. Sugary breakfast cereals -> Porridge (w/sultanas/raisins).
Sports drinks should be for sport, and even then, only if you’re doing something exceptional (i.e. glugging Lucozade when out for a 10 mile spin might be self-defeating). Snack foods (chocolates, crisps etc.) generally aren’t super-healthy, so packing some fruit or nuts might be an easier alternative.
Umm, and eat vegetables! They can get quite easily sidelined, because they don’t really fit into the fat-carb-protein triad, but that doesn’t mean they’re not important.The short answer to your problem is just to ‘eat less’, but that can be a bit blunt and difficult to follow. I’m repeating myself, but I’ve found that just generally improving my diet has done more for my cycling and weight than following a diet too obsessively. Most people have quite a few places where their diet could be improved, so rather than committing to something with a fancy name and message boards dedicated to it, I think it would be more sensible to improve your current diet piece by piece. Do try and keep track of what you’re eating though, and if you’re finding the changes difficult, allowing yourself a day off a week or something probably wouldn’t end the world.
Oh, and ride your bike. 😉
glynr36
LinusLarrabee wrote:glynr36
LinusLarrabee wrote:glynr36 wrote:A number of studies (long term) have measured the effects of various marco ratios on weight loss, and over 2 years there was no difference for all the variants.Unfortunately, as is often the case with the internet, there’s a lot of BS science out there – there’s even people who still insist the earth is flat or less than 10,000 years old. It seems people most often choose to believe what fits their existing world-view rather than what’s accurate. But that’s a whole different discussion and I could talk for hours about the work of people like Nobel prize winner Daniel Kahneman.
I’d be very interested to read those studies if you care to list them – especially if they have focused on plant based diets. As someone who keeps up to date with the latest research via NutritionFacts.org, I’m not at all familiar with these studies, but I am very familiar with the work of people like Dr’s Campbell, Esselstyn, Ornish etc. and it is a hobby of mine to actually read the research papers.
I’ll see if I can find them out, was a while ago when I read them.
I’d be interested to see the papers you reference to as well.I personally think the thing with paleo etc makes you think more about what you eat, so inadvertently you’re watching the calories more.
Eating 500 extra calories a day on paleo etc. or KFC, weight is still going on.
Eating 500 less calories a day on paleo etc. or KFC, weight is coming off (though don’t get me wrong the latter is still bad)LinusLarrabee
