- This topic has 15 replies, 9 voices, and was last updated 12 years ago by
bamilton wackademical.
October 29, 2014 at 2:39 pm #22653
bigshape
i took the plunge and ordered a new equilibrium disc last friday in 56!
unfortunately i received a call saying that they are now out of stock in 56 until jan/feb next year, so i’ve changed my order to a 58 to try out…
for current genesis owners, how are their frames on sizing? is it likely that i’ll get away with a slightly larger frame?
the 58 top tube length is 9mm longer with a 10mm longer stem. would a slightly shorter stem be an option if it feels too streched out? or would it effect handling too much?cheers!
I’m 6’1″ and ride a Genesis
I’m 6’1″ and ride a Genesis Volant in 56. I have short legs for my height so it’s more or less spot on for me – a nice comfortable ride over long distances.
bigshape
I went for the 58.
I took a
I went for the 58.
I took a mate with me (thanks matt!) for a second opinion and on the advice of the shop staff.
bike feels right – standover height is taller than my allez, but that was going to be the case with most bikes as the allez has a sloped top tube.
about to go out for a first ride – wet and rainy so perfect conditions check out the discs!AAN
I’ve had a Genesis for about
I’ve had a Genesis for about nine months. I expected to need a 54 but tried a 56 and it was, and is, a great fit. I’m 5’10” and have short (approx 30″) legs. Plenty of seat post exposed an the setup looks good.
On the face of it a 56 would seem pretty small for you.
bigshape
Dave Atkinson wrote:A 56cm
Dave Atkinson wrote:A 56cm Allez has a 565mm effective top tube, so almost exactly the same. genesis don’t publish stack and reach for their bikes unfortunately, which are the two measurements that are most directly comparable.you might find the 44cm bars a bit wide, mind
equilibrium 58 from the genesis site;
reach – 396
stack – 575allez 2013 56
reach – 395
stack – 574fingers crossed I might be ok!!!
Gman59c
I bought a Genesis
I bought a Genesis Equilibrium in the summer. I too deliberated over size for a couple of weeks. My carbon bike is a size 56 with a TT of 565mm. After reading many Genesis forums I plumped for the 58 Genesis, the top tube as said above is 567mm, so next to no difference. I built it up with a 110mm stem.Really happy with the 58, my mate says of all my bikes it looks the best fit. I am just over 6’1″. Also my brother in law took on spin on it the other week, he is 5’11” and said he found it comfortable.
mtbtomo
I’m 5ft 10 and normally ride
I’m 5ft 10 and normally ride 56’s – my three road bikes range between 560 – 570 top tube.If you’re over 6ft, I’d say 58 should be fine surely?
And I also use 44cm bars. Not at all a bit wide.
(But then I have had 20 years previously on a mountain bike!)
Brown dog
Noticed you live in Leicester
Noticed you live in Leicester ……… Give lovevelo a ring in derby 01332 295934
Had my equilibrium built and fitted by him. I took my old bike to his shop he took some measurements and made some changes to my current set up, different stem etcI then specified frame colour groupe set, wheels , bars and seat …. He then built the bike from the frame up .
I ended up with a hand built bike fitted for less than RRP price and fantastic service
dave atkinson
bigshape
Dave Atkinson wrote:genesis
Dave Atkinson wrote:genesis frames aren’t long in the top tube. So a 58cm equilibrium actually has a 567mm top tube and for that reason you could more accurately describe it as a 57cm, as the top tube measurement has much more bearing on fit than the length of the seat tube.best to check the top tube length of the bike/s you normally ride to see how they compare. In my experience, genesis road frames size up on the small side. swapping out the 120mm stem for a 110mm one isn’t going to do any harm.
cheers, that sounds a bit more positive! all hope is not lost on my dream bike!
bigshape
Rod Marton wrote:At a shade
Rod Marton wrote:At a shade under 6 foot I ride a 56cm Genesis and it fits me perfectly (though I was careful to choose a size with measurements/geometry almost the same as my previous bike). The 58cm didn’t. However I prefer a slightly short top tube. Whether the 58cm is suitable for you is something only you can tell, it depends very much on your position on the bike. Reducing the stem length will make the steering a bit more sensitive, but it’s a matter of personal choice how you like it. Handling on the supplied stem length is excellent, so it may well be perfectly acceptable with a shorter stem, but it’s a personal preference.cheers, Rod.
i’m also just shy of 6′ tall with around (32 1/2″ inseam)
i am expecting it to be too big, but have kind of got my heart set on that particular bike as it ticks all the boxes on my wishlist.
the problem is that i’m getting it from evans using their bike to work scheme and the voucher (which i have already) is only valid for 3 months…i currently ride an allez in 56 but can’t find the geometry chart to compare the two directly…
dave atkinson
Rod Marton
At a shade under 6 foot I ride a 56cm Genesis and it fits me perfectly (though I was careful to choose a size with measurements/geometry almost the same as my previous bike). The 58cm didn’t. However I prefer a slightly short top tube. Whether the 58cm is suitable for you is something only you can tell, it depends very much on your position on the bike. Reducing the stem length will make the steering a bit more sensitive, but it’s a matter of personal choice how you like it. Handling on the supplied stem length is excellent, so it may well be perfectly acceptable with a shorter stem, but it’s a personal preference.Sniffer
Fair enough. Good luck with
Fair enough. Good luck with new bike when you make your choice.
bigshape
Sniffer wrote:Buy the bike
Sniffer wrote:Buy the bike that fits you, not the one on special offer – or in this case the one available now.If a 58 is right for you OK, but if it is really a 56 that is right for you then don’t do it.
thanks, i’m just after an idea if it’ll be too big based on peoples previous experience of genesis sizing – have people gone to buy a 56 and ended up buying a 58 etc.
don’t worry, i’m not going to buy it if it’s too big 😉
Sniffer
