Sticky Ultegra Rear Mech
  • This topic has 4 replies, 4 voices, and was last updated 12 years ago by bigmel.
  • #22627
    orangesoul
    Hello,
    I’ve got a 10 speed rear mech on my commuting bike which is sticking where the cage meets the main body. I’ve cleaned and lubed it which works for a few rides but it then gets sticky again. Any suggestions for a permanent fix?
    Cheers, Ed
  • #818801
    bigmel
    Am I correct, you mean the
    Am I correct, you mean the pivot where the dual wheel cage meets & rotates on the parallelogram body?
    As the cable controls the body, it will have no effect on the cage, which rotates (due to pressure of a spring) to take the slack out of the chain.
    Remove the jockey wheels so that you can remove the chain from the cage. Now see if the cage has full movement.
    Make sure there is spring tension in the pivot – if it goes limp (without any tension) but still has movement then the spring is at fault.
    If the rotation is just stiff, work some penetration oil (GT85 or WD40) into the pivot and see if it frees up.
    #818799
    Nat Jas Moe
    Could be crud in the cable
    Could be crud in the cable housing worth blowing through with WD40 or some such.
    #818797
    orangesoul
    Hi Moby, all new cables from
    Hi Moby, all new cables from a month ago…but thanks for the advice and I’ll give lubing them a go.
    #818795
    mobydick64
    Try lubing the cable and the
    Try lubing the cable and the shifters. Better still, fit a new cable.
