- This topic has 29 replies, 25 voices, and was last updated 11 years, 12 months ago by .
Hi,
With the light fading and the weather starting to turn, I have realised that it is time to upgrade my rear lights.
I currently commute daily for 11. 5 miles on unlit, country roads. Most of the way, the speed limit is 50mph (well, that’s what the signs say…) and the roads feed the M40, so are busy but free-flowing with other commuters. As such, I think I need to be taking more precautions to make sure I’m seen.
At the moment I use a couple of cheap rear lights – which do the job – but I think it’s time for me to upgrade. I’m just unsure on what to get.
Here are my criteria;
1. Money – I am happy to spend a bit of money to get the right light(s)
2. Waterproof/resistant – I don’t have mudguards or plan to stop cycling through the winter so I want the light to be tough enough to take everything the weather can throw at it
3. Fastenings – I guess this is a similar point to above but I have read some reviews about bad fastenings and I don’t want to worry about my light falling off
4. Bright – Last, but not least, I want to get something bright enough so that I am clearly seen from a long way off, especially in bad weather when a sleepy driver is approaching
So far I have been looking at three models: Exposure TraceR, Cateye Rapid X and Knog Blinder. They all look good but also seem to have varying issues around fastenings, charging, brightness, etc.
Which would you recommend? Should I be considering something else?
Thanks for you help (and reading to the end of this!)
Rich
