- This topic has 38 replies, 29 voices, and was last updated 11 years, 10 months ago by
Judge dreadful.
October 1, 2014 at 8:08 pm #22494
Mr BiB
I am looking to upgrade my Cube Attempt to something in Carbon Fibre, but an unsure as to whether
to go 105 5800 or Ultegra 6800. is ultegra worth the extra £300 ??? -
Dollo
The earlier posts have been
The earlier posts have been very useful for me but I have a particular decision dilemma that I would appreciate advice on.
After 7 or 8 years on my first road bike – a Dawes Giro 200 with Shimano 150 8 speed – a faithful but now broken steed – I have the choice of a BH Quartz with Shimano 105 10 speed or Ultegra 11 speed.
Both are on sale with the Ultegra having the bigger discount but still a price increment for the Ultegra of $400 (about 200 pounds).
I ride for pleasure about 100 miles a week but live in hilly area.
The jump up to either bike from my old Dawes will be fantastic but is it worth paying the extra for the Ultegra?mtbtomo
I think there was a bigger
I think there was a bigger difference between older 105 and Ultegra (esp the chainset and brakes). Cables and general set up could potentially make more difference to how the groupset feels than difference in materials/manufacturing quality.I’d be more bother by the step down from 105 to Tiagra. Tiagra feels quite light action but flimsy and the hood/lever shape isn’t as good.
I’ve probably already posted this somewhere, but I’ve got full 6700 on one bike; 5700 shifter/Microshift Arsis derailleurs/6800 Ultegra brakes on another; full 5800 on another and Tiagra on the commuter. There’s not a lot of difference between any of the set ups except the Tiagra set up.
You probably won’t notice the difference if you can’t ride the two groupsets back to back.
Colin Peyresourde
There aren’t a lot of Ultegra
There aren’t a lot of Ultegra owners responding here (respondents appear to have opted for 105 and are happy with their lot). To be fair I cannot comment on the latest iterations, but my Ultegra is crisper in the change and smoother all round from the 105s I’ve ridden. I’m not going to say that it’s a massive difference, and I think the price differential reflects that (compared to the giant leap to Dura Ace). But you do feel the quality.andyp
new bar tape a few/ half a
new bar tape a few/ half a dozen times a year is no bad thing anyway, let alone for the advantage you get from new cable outers.notfastenough
KiwiMike wrote:Scoob_84
KiwiMike wrote:Scoob_84 wrote:Both my bikes run 105 (5800) and the difference in the performance between the two was huge. The newer of the two group sets shifted like a dog whist the older set was light as a feather. If you were blind tested you’d think they were different groupsets.The only difference between the two was that i was using 2 year old jagwire cable outers on the new groupset whilst the older set was set up with brand new cable outers.
THIS.
Swap out your cables every 1-2000km. It’s £10 worth of hardwear* and 20 minutes, max. for a vastly improved experience.
* a lot less if you buy in bulk.
Are you just referring to swapping the inners though? Swapping the outers necessitates new bar tape and the time to fit, surely?
Sidi 700c
I have the 105 5800 11 Spd
I have the 105 5800 11 Spd gruppo and there is only a weight difference to me that i notice right away.Welsh boy
I have just changed from 105
I have just changed from 105 calipers to ultegra and the improvement is huge, if the rest of the groupset is as different then it is worth the £300 (I use SRAM apart from the calipers because i prefer the shifting and lever shapes of the SRAM stuff)Anonymous
difference in retail price
difference in retail price between 5800 and 6800 groupsets is only about £150.jamtartman
Yes it is.
Yes it is.
fukawitribe
jamtartman wrote:I run 105
jamtartman wrote:I run 105 (except for my crank) and I swap out the cassette from time to time for different ratios, and one of the cassettes is Ultegra. Ignoring the difference in ratios, the Ultegra cassette feels much better. Gear changes are sweeter, and somehow the feel through the drive train is better – more direct. It makes me want to change the rest of the drivetrain to ultegra.Is the Ultegra a closer ratio cassette ?
jamtartman
I run 105 (except for my crank) and I swap out the cassette from time to time for different ratios, and one of the cassettes is Ultegra. Ignoring the difference in ratios, the Ultegra cassette feels much better. Gear changes are sweeter, and somehow the feel through the drive train is better – more direct. It makes me want to change the rest of the drivetrain to ultegra.mtbtomo
Shimano 105 5800 is probably
Shimano 105 5800 is probably the closest that 105 has ever been to Ultegra. The brakes are the same dual pivot, shifters only miss the carbon levers, and the outer chainring is not hollow like Ultegra.If it was 5700 vs 6700 Ultegra, I’d have gone for the Ultegra, but for the new stuff (5800/6800), as per previous posts its the weight that is the main difference.
Swami Dave
Can I stick in a SRAM-shaped
Can I stick in a SRAM-shaped curve ball…? I’ve been using various iterations of 105 for years and yes, it’s improved vastly to the point where weight appears to be the only difference between it and Ultegra. However, I’ve recently switched to SRAM Force on my winter bike and the difference between it and 105 is incredible. I’m a total convert to their Double Tap levers, which are so much easier to use than 105. There isn’t a single bit of chain rub or jumping on the cassette and the shifts are light, quick, accurate and immediate. If you can give one a try then I’d recommend it before shelling out for new 105. I’ve been really, really impressed.
KiwiMike
THIS.
macrophotofly
Not if you go for the 5800
Not if you go for the 5800 105 spec – 11spd and some of the brake development from ultegra has shifted down to 105.
Be careful as lots of retailers are still selling bikes with the old 5700 105 groupset on them -
