- This topic has 22 replies, 15 voices, and was last updated 12 years, 1 month ago by
3wheelsgood.
September 17, 2014 at 8:52 pm #22402
ta2dwez
With all the brands and variations available in a little confused as to which chain I should get. I have a shimano 8 speed on at the moment but is “stretched” and need replacing. I see a lot of love for the KMC chains, and I see the SRAM are compatible. Could someone advice me or post a link (pun not intended) to a guide in the best chain for me.
Cheers
3wheelsgood
IngloriousLou wrote:Bear
IngloriousLou wrote:Bear hands :)
=)) 😀 =)) 😀 =)) 😀 =D> =D>IngloriousLou
Bear hands
Bear hands 🙂farrell
Beatnik69 wrote:
I’d haveBeatnik69 wrote:
I’d have thougt the claws would make them a bugger to work withClaws? Huh?
IngloriousLou
One of these in the tool box
One of these in the tool box is well worth ithttp://www.chainreactioncycles.com/bbb-open-link-closing-link-tool-btl77/rp-prod47439
Beatnik69
3wheelsgood wrote:wyadvd
3wheelsgood wrote:[quote=wyadvd]KMC: You just need to develop the skill of attaching / detaching the magic links with your bear hands which is easy once you have the knack. Create some slack in the chain the bend the chain across its width to loosen the link. Then pull the two halves of the chain together. Needs practice but its worth it for on road repairs. If you use a shimano chain, if it snaps you’re effed, as you can’t fix it with a missing link on the road and they are b@ggers to fix with a chain tool. KMC however can be fixed easily on the road. which is a big advantage in the middle of FEBmy method: https://www.youtube.com/watch?v=NG2WW5CTIqc%5B/quote%5D
Where can I get a pair of them there bear hands to add to my toolbox????? 8}
I’d have thougt the claws would make them a bugger to work with and it must be a nightmare trying to get chain lube out of all that fur. 😀wyadvd
wow thats useful info thanks
wow thats useful info thankswyadvd
If you replace your chain on
If you replace your chain on the 0.75 point on chain wear tool, you may get three chains per cassette.3wheelsgood
wyadvd wrote:KMC: You just
Where can I get a pair of them there bear hands to add to my toolbox????? 8}wyadvd
If you enjoy carrying your entire tool box you can try this method:
3wheelsgood
I was always taught that
I was always taught that replacement of worn chain is inextricably linked with the replacement of cassette – am I out of date on this? :/kev-s
I run dura ace and ultegra 10
I run dura ace and ultegra 10 speed chains on my bikes, the trick to get the kmc power link to lock is to make sure the right hand crank arm is facing forwards, connect the kmc link together making sure they link together just a few links before the chain goes on to the chainringnow apply the front brake and using your foot apply pressure to the pedal until you hear the kmc link snap into place
Been doing this for years and it seems to be the easiest way
joemmo
ta2dwez wrote:mike the bike
ta2dwez wrote:mike the bike wrote:By the way, a KMC Missing Link fits Shimano chains ( or Campag’) just fine.Im 100% sure your right, i just couldn’t for the life of me get it to lock :|
Could have been a dodgy link. I had one on a recently bought kmc that would not close so I just reused the old one.
ta2dwez
mike the bike wrote:By the way, a KMC Missing Link fits Shimano chains ( or Campag’) just fine.Im 100% sure your right, i just couldn’t for the life of me get it to lock 😐
mike the bike
Not directly relevant to the
Not directly relevant to the thread because I’m talking about ten-speed chains, but illuminating just the same ….A few months ago Velo magazine published the results of a chain longevity test. They took examples from just about every leading manufacturer, and a few I’ve never heard of, and ran them under lab’ conditions for thousands of hours whilst liberally dousing them with sand.
The longest lasting, if my memory serves me correctly, was Shimano’s Dura Ace but very close on its heels was their 105, at less than half the price. I have since bought three for my store cupboard and with a little luck they should last me five years.
