Chain Advice Needed
  • This topic has 6 replies, 5 voices, and was last updated 12 years ago by baracas77.
  • #22401
    baracas77
    Hi,
    I want to replace my cassette (11spd Ultegra) with an 11-32 as up to now, I’ve just been doing flattish Du/triathlons. I’m planning on hitting some hills and I’m not the lightest rider out there and like to have a high cadence. The crank is a 52/36.
    Clearly, I wouldn’t purposely run it at 52 – 32 but sometimes it happens and as it is at the moment, the chain is too short. Looks currently to be a 106 link chain.
    So, question is:
    Is it simply a matter of getting a longer chain or do I also need the GS version of the RD with the longer cage to take up the slack?
    Thanks in advance..
  • #814787
    baracas77
    Cheers Edster, that’s exactly
    Cheers Edster, that’s exactly what I needed.
    #814785
    edster99
    Yes, get a longer one and
    Yes, get a longer one and take some off. Calculators are available to know how many links you need : start here
    http://www.machinehead-software.co.uk/bike/chain_length/chainlengthcalc.html
    #814783
    IME a chain will have 114 or
    IME a chain will have 114 or 116 links, you remove links as needed when installing it.
    #814781
    baracas77
    Thanks for the replies guys.
    Thanks for the replies guys. As for the chain length is it case of buying a longer chain and possibly reducing it down as buying extra links doesn’t look like the done thing.
    #814779
    CanAmSteve
    Along with a longer-cage RD
    Along with a longer-cage RD (which you may already have) you need to keep an eye on just how much chain slack the RD can pull without going slack on small-small.
    IIRC, all Ultegra RDs can handle a 30 rear cog “officially” which means 32 in real life (usually). But I doubt it can handle the difference in chain slack from 52/32 to 36/11. Typically you size a chain big/big (without the RD in play) then add two links. Give it a go using a chain with a removable link if available and then run it on a stand threaded through the mechs. Check how slack it is in the smaller range, as it will slap your chainstay (or worse).
    I’d say you almost need a MTB RD for that great a range. You could pick up a compact 50/34chainset and run that with the 32 rear (just barely, I think).
    #814777
    matthewn5
    Yes for 32 you’ll need a GS
    Yes for 32 you’ll need a GS rear mech. The SS only goes up to 28t.
    You could swap out the chainrings for smaller ones, they are interchangeable now.
