Mavic Tyre Direction
  • #22258
    andycoventry
    Friday silly question time:
    Mavic WTS tyres have a sort of ‘V’ profile on the outer edges, and I have them mounted so that when rotating the front of the ‘V’ (if it were complete) connects with the gound first.
    Now I assume tyres with a profile like that are uni-directional, and I have never given it much thought, however, in the article for the new Aeroad they use mavics, but the photo shows the tyre facing the other way.
    /content/news/128126-first-ride-canyon-aeroad-cf-slx
    Who’s right, or doesn’t it matter?
  • #812065
    Guernsey Donkey
    Mavic seem to have recently
    Mavic seem to have recently changed.
    I have a set of 2013 R-SYS SLR’s and they came with the old version of Griplink/Powerlink 23mm and the tread on those were both the same way. (tyres came fitted and rear can only go on the bike one way and the front is marked on the wheel due to the directional braking surface).
    The 2015 version has the front wheel reversed.
    #812063
    leveller
    I’ve just had some of these
    I’ve just had some of these and there is now a rotation arrow on the sidewall. It does seem like the tread is arrowing towards the rider and just doesn’t seem right but apparently it is correct.
    #812061
    Mike Cotty
    Hi Andy,
    Just to clarify for
    Hi Andy,
    Just to clarify for the new Mavic Yksion Pro Powerlink (rear) and Griplink (front) tyres.
    The rear tyre direction is intuitive and should be mounted as if the tread was forming an arrow to show the way to go.
    The front tyre however is slightly less intuitive and should be mounted so that the tread shows a “V” (instead of an arrow) while you’re on the bike looking at it. This is to give better water evacuation in the curves. Should you ride in dry conditions the mounting direction will be of less influence.
    For clarity mounting direction arrows will be added on the tyre sidewalls in the future.
    I’ve attached a diagram to confirm the above.
    Hope that helps. Ride safe and enjoy!
    Mike Cotty
    Mavic Community Manager
    #812059
    Binky
    drfabulous0 wrote:Hang on ,
    drfabulous0 wrote:
    Hang on , you rang Wiggle? Care to share the phone number?
    You need a ouija board and some chicken bones (not kfc )
    #812057
    dunnoh
    fukawitribe wrote:monty dog
    fukawitribe wrote:
    [quote=monty dog]Tread pattern makes no difference to how a road tyre performs – as said, the pressure between rubber and road is so high it simply pushes the water into the cracks in the tarmac.
    Tread does make a difference on road tyres, in the wet at least, it’s just not a big effect compared with compound, pressure, compliance etc. Here’s some interesting points from people that might know a few things
    http://velonews.competitor.com/2014/05/bikes-and-tech/technical-faq/technical-faq-tire-grip-wet-conditions_328827%5B/quote%5D
    That’s really interesting. I ride in all weathers and listened recently to people saying that the grip on slicks is OK in the rain. I’ve had a go and I’m going back to the Paves.
    #812055
    fukawitribe
    monty dog wrote:Tread pattern
    #812053
    monty dog
    #812051
    drfabulous0
    #812049
    Yes i have used conti
    Yes i have used conti gatorskins for years and as you say they have an arrow moulded in to show rotation direction, last lot i bought ( from wiggle ) no arrow
    rang wiggle they checked all the rest of stock no arrow the guy said he didn’t think it mattered, so one year it does, next year it doesn’t Duh!
    #812047
    drfabulous0
    Doesn’t matter, water is
    Doesn’t matter, water is displaced by the tyre’s rounded profile and the road surface, not the V profile. It’s not possible to aquaplane on a road bike like a car can so tread is not required. Obviously the tread pattern serves a different purpose on a mountain bike but people seem to have the perception that tread = grip.
    #812045
    Martyn_K
    Continental have a little
    Continental have a little arrow on the side wall of their tyres indicating the direction of rotation. Having fitted many a Conti i know that the arrow goes on the non drive side of the wheel. It is not a painted arrow, just moulded in to the rubber.
    Maybe there is a little indicator on the Mavic’s??
