- This topic has 7 replies, 7 voices, and was last updated 12 years, 3 months ago by .
Hi all, I have an Orbea Orca Gold that I recently bought and had my usual Elite Custom Race cages fitted. Due to the shape of the frame the cage on the down tube cannot be put on the highest bolt hole as the cage will rub the frame so the top bottle touches the bottom bottle and as a result doesn’t sit fully into the cage by about 1cm.
Almost all decents result in the bottle shifting upwards which means constant checking/twitchy riding.
I’ve cut the back away slightly from the top cage so I can position it slightly lower down which seemed to work but now the rear bottle seems to shift upwards on bad surfaces, pot holes etc. Bottles still touch but both are now fully in their cages.
Any suggestions as to how I can get over the problem.
Happy to change the cages as I find myself constantly checking I’m not going to lose bottles on decents and bad road surfaces. I use SiS 500ml bottles, happy to changes those too if necessary.
Thanks for any input.
Jon :/
