- This topic has 4 replies, 4 voices, and was last updated 12 years, 3 months ago by .
Hi all
Just looking for some general feedback from you all on whether wheel/tyre rub and indentation on carbon bike chainstays is anything to be overly concerned with? I ride a 2010 Scott CR1 Pro with 25mm (Michelin Pro4 service course tyres) on Dura-ace C24s or Mavic Cosmic Carbone SLs.
My LBS on a recent frame inspection had declared that my chainstay was ‘cracked’ based on a quick visible inspection (all of two minutes). Having looked a bit closer myself afterwards, what they are mainitaining as a crack is a fairly uniform indentation in the paintwork on the inside of both chainstays in line with where the tyre is closest to the chainstay. There is not a lot of clearance for 25mms on my Scott CR1 however there is certainly no apparent chain rub when climbing or putting the power down.Having researched on the internet, there are a number of posts identifying a similar issue either due to wheel flex or where new tyres have a rubber edge or stalks which catch on the chainstays.
http://www.cyclechat.net/threads/back-wheel-tyre-scuffing-inside-of-chainstays.115764/
I intend to get a second opinion from another LBS for piece of mind but just wanted to gauge the forum here for experience here? Perhaps I need to revert to 23mm tyres to prevent any further wear on the paint lacquer??
Thanks
Brendan
