Are all ANT+ sensors compatible?
  • This topic has 11 replies, 9 voices, and was last updated 12 years ago by Nat Jas Moe.
  • #22058
    Nat Jas Moe
    Now I am looking to improve my performance and am looking at cadence. I have a bryton 20 which says that it is ANT+ and can take both speed and cadence sensor data. My question is twofold first will it handle a dual sensor and secondly will I have to buy a bryton dual sensor(s)? I feel a little silly asking but would like to know. Many thanks in anticipation.
  • #807325
    Nat Jas Moe
    Have been to this site and
    Have been to this site and Bryton is not on there. :S Again thanks for all the advice will now try nd make up my mind about which Saul sensor to get.
    #807323
    trek-buyer
    As mentioned above, go to the
    As mentioned above, go to the web:
    http://www.thisisant.com/directory/
    Find the (receiving) device you have, then you will be able to check the compatible options.
    I recently bought a HR monitor from Decathlon to pair to both my Timex and Garmin devices, works a treat. Considered the cadence sensor, but to be honest it looked “cheap” quality (although what did I expect for <£20). Rob
    #807321
    DrJDog
    If you’re only interested in
    If you’re only interested in a cadence sensor, the new garmin one is a brazilian times neater than the old double monstrosity, and you can pick it up for around £30-35. It works with the Rider 20, though you have to start pedaling before you turn on the Bryton for it to be picked up.
    I have a rider 20 with a Garmin HR strap and the new Garmin cadence sensor, and it all works reasonably well.
    #807319
    Anthony.C
    If you look on the ANT+
    If you look on the ANT+ website they have a list of everything that is compatible for each product.
    #807317
    pablo
    decathlon combined sensor
    decathlon combined sensor works fine on my garmin 510 usr one on my winter/commute bike
    #807315
    fukawitribe
    JonD wrote:>You should also
    JonD wrote:
    >You should also beware of some of the cheaper sensors (especially Decathlon) which, whilst compatible, don’t broadcast their sensor ID in a way which allows all computers to recognize them.
    >completely different protocol
    Interesting..Garmin screw it up too. The latest Etrex line (came out a few years ago) can pick up cadence, hrm. (Etrexes generally are oft-used by the audax crowd.)
    Can I use a cadence-only sensor ? – can I heck ! – only the (more expensive) combined Garmin sensor works, yet it does nothing with the speed pickup.
    Interesting – the only Etrex on the ANT+ product list is the E30, and that’s only spec’d to support HRM, temp and Geocache.. half surprised it works with cadence at all. I guess the audax crowd would be less interested in the more performance oriented profiles but even so, it’s a weird choice of navigation aid.
    #807313
    JonD
    #807311
    step-hent
    You should also beware of some of the cheaper sensors (especially Decathlon) which, whilst compatible, don’t broadcast their sensor ID in a way which allows all computers to recognize them. I bought a Decathlon one, only to find that the Garmin wouldn’t recognize it. I then found out that I would also need an ANT+ sensor for my PC in order to find out the sensor ID and then type that into my Garmin. Ended up taking it back and getting a Bontrager one instead.
    #807309
    vadido
    I work on ANT+ software and
    I work on ANT+ software and the only issue you may have is the combined ANT+ Speed and Cadence sensor has a completely different protocol from the separate Speed and Cadence sensors.
    Normally computers support both.
    For example I recently bought a Rox 10 which makes no mention of supporting the combined S&C sensor in the documents/website but it does, I use it with the cheapo Decathlon sensor which is pretty reliable.
    #807307
    Nat Jas Moe
    I thought that would be the
    I thought that would be the case but wanted to check before splashing the cash and finding that I’d messed up in some way. Cheers for that.
    #807305
    fukawitribe
    The ANT+ speed, cadence and
    The ANT+ speed, cadence and combined speed/cadence profiles are well specified standards and should be supported by your Bryton and most sensors you’re likely to meet, e.g. Garmin, Bryton, Bontrager.
    FWIW I currently run a Bryton 35 with a bontrager combined speed/cadence sensor and it works absolutely fine.
