Another question about cheap speedo into cadence question.
  • #22043
    ta2dwez
    I bought a cheap wireless speedo from lidl (£6.99) earlier in the week and im currently trying to use it as a cadence meter. I have a magnet on the left hand crank arm and the receiver on the chain stay with the display on the cross bar so i can see it by looking down. The possible problem is. I have measured the distance from the BB to the magnet (170mm) i have then multiplyed that by 2 and then multiplyed that by Pi. (170 x 2 x 3.1416) = 1068 rounded down. I have put that into the computer as the wheel size and im using KPH but the read out does not seemright? my comfortable cadence according to the computer is 55 but that number seems low?
    i have been looking around online and they mention gear ratio’s as well.
    Am i missing something in the calculations?
    Im not overly fussed as i can use the computer reading as a standard (55) but it would be nice to have the correct cadence.
    Any help would be great
    Thanks
  • #807089
    Tjuice
    If you can put in 16667
    If you can put in 16667 (instead of 1667) it should show 90 cadence as 90kph, rather than 9.0kph.
    However, two potential problems with doing this:
    1) calibration is unlikely to allow you to put in a number as large as 16667 (hence the 5 magnets thing in the instructables)
    2) Even if you could enter 16667 it’s likely that your cycle computer would not want to display speed greater than 100kph, so whenever your cadence goes above 100, it would not display!
    Sounds likely that you have already found the best compromise.
    #807087
    ta2dwez
    It’s showing 90 cadence as
    It’s showing 90 cadence as 9.0kph
    #807085
    FatAndFurious
    Glad to help.
    Looks like the
    Glad to help.
    Looks like the computer is using wheel circumference in cm.
    Don’t forget to show your friends your average “speed” after a ride too…. 🙂
    #807083
    ta2dwez
    I put in 1667 as the tyre
    I put in 1667 as the tyre circumference which was asked for by the computer. I used a cadence metronome app from the play store https://play.google.com/store/apps/details?id=com.ndev.cadencemetronome&hl=en and it matched, i have no idea how the math works 😕 , but it works, im happy! 😀 thanks for all your help!
    #807081
    FatAndFurious
    First off, check what the
    First off, check what the computer is expecting for wheel size.
    Is it expecting a Diameter or a Circumference?
    Is it using millimetres, centimetres or inches ?
    The size of your crank is irrelevant – you just need the number of times per minute that the magnet passes the sensor.
    Here comes the science:
    For a reading of 60kph, the computer calculates that a wheel has rolled 60,000m in one hour.
    60,000 metres/hour = 1,000 metres / minute
    If you think of the wheel as representing your chainring, then at a cadence of 60rpm, the chainring has turned 60 times in that minute. A “wheel” turning 60 times in a minute covering 1,000 metres means that the circumference of the wheel is (1000 / 60) = 16.6666 metres
    Divide circumference by Pi to get diameter
    16.6666 / 3.14159265etc = 5.305 metre diameter.
    Now, a standard 700×23 wheel has about 2.1 metres circumference, or about 0.668 metre diameter, so here is where your problem is.
    If your computer doesn’t let you set a diameter up to 5.305 metres / 5305 mm / 208.86 inches, then you can’t use a single magnet. This is why I suspect the instructables article is using 5 magnets – the computer is getting 5 pulses per revolution, so the configured wheel size can come down to 1.061 metre diameter, or 3.333 metre circumference, which is more likely to be in the range of accepted values.
    So your formula is (for cadence using KPH, sizes in metres)
    Circumference = 16.666 / number of magnets (Instructables has 5 magnets, hence their value for wheel size of 3333)
    Diameter = 5.305 / number of magnets
    For MPH, it’s the answer from the KPH formula multiplied by 1.609344, so
    Circumference = 26.8224 / number of magnets
    Diameter = 8.538 / number of magnets
    Let us know if that helps?
    #807079
    ta2dwez
    That link is where I got the
    That link is where I got the idea from. But I have one magnet on the end of the crank arm
    #807077
    the infamous grouse
    #807075
    andyp
    ebay, Cateye Astrale.
    I think
    I think I chucked a couple away a few weeks ago, from the old computer and light retirement home in the garage, sorry 🙁
    #807073
    ta2dwez
    Exactly, all I want is the
    Exactly, all I want is the RPM of the cranks turning. But for the life of me I can’t work it out :S
    #807071
    Leeroy_Silk
    I know what your trying to
    I know what your trying to achieve but to me the calculation seems overly complicated. All you want the sensor to count and calculate the average of your cranks rpm, not necessarily the speed at which they’re passing the sensor. Therefore, the distance from the sensor to the BB I would have thought is irrelevant. By this same reckoning the gear ratio should have no influence either.
    Sorry I can’t help further.
