Slowest of slow punctures?
  • This topic has 6 replies, 5 voices, and was last updated 12 years ago by Flying Scot.
  • #22016
    meach
    For around a month now my front tyre has been deflating, but not fast enough to affect my riding in any way. Can do four hour rides with no noticeable change in tyre pressure.
    When I go to get my bike out the next day, the rear tyre is still up at 100psi, yet the front is down at 20psi.
    Any ideas? On removing the tube I couldn’t find any puncture.
  • #806421
    Flying Scot
    andycoventry wrote:Pump it up
    andycoventry wrote:
    Pump it up and stick it in a bath full of water to find where the air is coming from.
    I had assumed he had already done this!
    #806419
    andycoventry
    #806417
    meach wrote:replaced the tube
    meach wrote:
    replaced the tube when i took it out to inspect this week, just wanted to know what the issue was and if it was fixable
    There’s probably a very, very, VERY tiny hole in it.
    I fixed a puncture in my wife’s rear tyre, checked it, all seemed fine. Still hard after an hour, close to flat after a day. CBA, it’s an old, cheap 26″ tube so I stuck a spare on instead.
    It may be repairable but is it worth the effort? Keep it as a toolbox spare or something.
    #806415
    bashthebox
    My turbo tyre does that – not
    My turbo tyre does that – not sure if there’s a turbo specific tube or something? Just took a tube out of a second hand wheel that was deflating in a similar way and the tube said ‘turbo’ on it too. Weird.
    #806413
    meach
    Flying Scot wrote:2 quid, fit
    Flying Scot wrote:
    2 quid, fit a new tube, probably the valve passing at high pressure, holds at low pressure.
    #806411
    Flying Scot
