- This topic has 35 replies, 14 voices, and was last updated 12 years, 3 months ago by
Gordy748.
July 6, 2014 at 1:49 pm #21842
Sensible
I have been riding for a couple of years now and when i bought my first road bike I got quite a nice one so that I wouldn’t have to upgrade too soon.
I have a carbon framed bike, with decent kit. It has fairly light wheels (DT swiss hubs), that are 1775g for the pair. I use Conti tyres.
I mainly ride on my own for fitness, but occasionally with friends and have done a couple of 100 mile charity rides. I average about 35-40 miles when I go out once per week and average about 15 mph. I find hill climbing hard, but am getting better and live in a very hilly area.
I understand that My wheels are good but at the bottom end of Giants decent wheel range.
Was thinking of I upgrading my wheels to something lighter, maybe 1350-1400g.
I am also unsure about the benefits of aero wheels, most of which don’t seem any lighter than what I have.
If I was to buy some nice light wheels, will I notice any difference.
notfastenough
Soul wheels have a test ride
Soul wheels have a test ride program, and one of their wheel sets got a great review on here. Look them up, I think they courier the wheels out to you or something.drfabulous0
Don’t you have a friend or a
Don’t you have a friend or a local bike shop who would lend you a set of better wheels to have a go on so you can make up your own mind?intheshed
What I meant to express was
What I meant to express was that I agree with ajmarshal1, whilst empathising with Sensible’s original post.I’ll go and get me coat…
intheshed
I agree with Sensible re any
I agree with Sensible re any of the top tier Mavics, Campags or in my case, Fulcrums. I’m late 40s, 13 stone and ride hilly terrain at similar average speeds. Went through brief periods of ownership of two lightweight alloy wheelsets in the £300 to £500 price range that would initially launch me up any climb slightly quicker but then drive me crazy for the rest of the climb, flexing noticeably.My bro had many happy years on Eurus’ and then went onto Fulcrum Zeroes and on his recommendation I took the plunge with the Zeroes which I reckon are ace. Super stiff, a little heavier at 1600g, but combined with Conti tyres and lightweight tubes, an absolute joy to ride on. They feel so much more responsive when I put power down and have sharpened up the handling of the bike significantly. I think it’s that latter feature that gives me the feeling that I’m a bit more ‘brisk’ across a variety of terrain.
Read on roadcc that there’s an uprated version of the Zeroes in the pipeline so there could be deals on the existing model to be had.
Sensible wrote:Don’t get me
Sensible wrote:Don’t get me wrong, I am not into buying kit for the sake of it…and yes I am out there cycling hard up those hills. Today 49 miles, average 15.3 mph with 2500 feet of climbing.
http://www.strava.com/activities/163287279
I am asking the question whether I would notice the difference with lighter wheels. I am not into throwing money at it and not putting in the effort.It sounds like you’re wanting a subjective reaction. Like with clothes and music, sometimes you just have to decide for yourself.
ajmarshal1
I am asking the question whether I would notice the difference with lighter wheels. I am not into throwing money at it and not putting in the effort.For what it’s worth. I notice a marked difference between my Aksiums / Fulcrum R7s and my Ksyriums / Shamals. Whether weight is a factor over hub quality / wheel stiffness in that difference is up for debate. However, more often than not I am faster over regular routes when riding on my dressy wheels. Moreso on undulating or hilly rides, less so on the flat.
Sensible
Sensible wrote:Good idea
Sensible wrote:Good idea about doing a hill with and without a water bottle….but isn’t weight cut from wheels more noticeable than static weight because of rotating mass?Not all the weight saved in a lightweight wheelset is from the rim, otherwise they would be as thin as baking foil.
A rule of thumb: for 100 meters of height gained, 1 kg less weight saves 2 seconds. The difference between adding 1.8 kg of water to the bike or in the tyres is 0.9%. Hardly dramatic.
Ceramic bearings make sod-all difference, don’t believe the hype. To get better at riding hills you have to ride hard up hills. However, when you do see an improvement it is infinitely more rewarding than buying kit.
bikebot
I doubt if it will make much
I doubt if it will make much difference to your speed, but neither will it harm it and your backside will thank you if you go up a tyre size. Rider weight is a factor and 23 should really for the whippets amongst us.
Sensible
Thanks for the advice so
Thanks for the advice so far… bit of a mixed bag really as to whether I would notice any real difference by cutting about 375g of weight from a wheelset. Good idea about doing a hill with and without a water bottle….but isn’t weight cut from wheels more noticeable than static weight because of rotating mass?Noelieboy.. I am running 23mm Conti GP4000S. My bike came with 23mm Giant P-SLR1 tyres and they were fine, so when I wore them out I just bought 23mm Conti tyres. Would I gain anything from 25mm tyres. I haven’t got much clearance but I guess there is more than 2mm.
Don’t fancy tubular wheels…isn’t that when you glue the tyres to the wheel. Sounds a bit too fussy. How do you fix a puncture? (excuse my ignorance)
I have had an issue with my rear hub in the past when the spring came off my pawls and I initially had no drive at all. After tinkering with it I managed to get some drive but couldn’t free wheel. When I had it fixed and later serviced, the LBS said when I do change my wheels I could get some with better hubs (he intimated they weren’t that good). I know DT Swiss have a good reputation but most of their hubs have star rachets. Mine has a spring and two pawls. So part of my upgrade would be to get some good quality hubs that roll well, maybe with ceramic bearings. I also use my bike all year round. Two winters have started to wear the rim, so in time I will need to replace the wheels anyway. I am just thinking ahead and maybe treating myself early.
Sensible
Sensible
Estimated all-up weight =
Estimated all-up weight = 94kg.Weight reduced by 1,400g wheelset = 375g.
This as a percentage of total = 0.4%.
Try riding a decent climb with a 2/3 full bottle then take it out. Can you tell the difference? Centrifugal force isn’t a big factor, even with very light rims, as you’re still pulling 93.625 kg against gravity.
If your goal is having some smart looking wheels on your bike then you are truly spoilt for choice. However, lightweight or aerodynamic wheels won’t help you go better up hills.
Gordy748
As a custom wheel builder, I
As a custom wheel builder, I should say “yes, of course they will!”, but only with caveats.What you have aren’t bad wheels at all. Sub-1,800 g for a basic wheel set is not that heavy, DT Swiss are my go-to hubs (phenomenally under-rated) and Continental’s 4000 tires are what I’d recommend as an all-round clincher tire. You are using 25mm wide tires, by the way, aren’t you?
A wheel upgrade is an incremental improvement. Per comments above, 15 mph on a hilly route isn’t shabby (especially with a 13 st body), and new wheels will not make you hurt any less, it will just make it last for a slightly shorter time.
That said, a significantly lighter set of wheels can help in a couple of ways. If your hills feature variable gradients then the lower centifugal weight will allow you to accelerate more easily as the gradient drops, which will reduce time and/ or the pain. Over a series of hills, the slightly less fatigue you get will be compounded. In other words, lighter wheels might shave 5 seconds off hill 1, but 50 seconds off hill 10.
For your budget, I’d go with alloy rims and DT-240 hubs. It’s pretty easy to build a set that’s near 1,200 g, but strong enough for you.
Adding a couple hundred more quid will get you access to carbon rim wheels. If you choose this, I’d only recommend tubular; they are lighter and cheaper than carbon clincher and there aren’t any overheating issues. For a little over 1,000 quid you will be able to get a wheel set for almost 1,000 grams, again with DT-240 hubs. At this point the difference will feel significant; you have a lot less weight and the better handling of tubulars to boot.
Noelieboy
Hi, I would love to recommend
Hi, I would love to recommend these wheels, Swiss side Francs.
http://www.swissside.com/shop/franc-wheelset
I wanted to upgrade my shimano RS500 (1800kg) & I was looking around for ages. comparing weight & price when I came across the swiss side brand.
I was on a more limited budget than you of £300 & I can honestly say that the wheels for the price are amazing.
they’re not my everyday wheels, I just use them for crit & road racing around lancs & derbys & for the hilly TT’s in Glossop. the hubs are buttery smooth & roll for ages. for your budget however you could upgrade to the gotthard wheels or even the new hadron deep section wheelset which would have you going faster 🙂
I thought your weight might be an issue don’t think you’d be have a problem. the max rider weight is 105kg.
check em out. -
