- This topic has 12 replies, 7 voices, and was last updated 12 years, 1 month ago by .
The seatpost on my Allez is well and truly seized-I took it to my LBS and they could do nothing with it. ~X( I have tried all the different approaches except for sticking it in a bench vice- unfortunately I don’t know anyone who has one (although to be honest I don’t think it will make much of a difference anyway). The heating/freezing approach doesn’t work because both post and tube are aluminium so expand and contract together. I’ve tried penetrating fluid (loads of it) and every other suggestion I can find, so it looks like I am going to have to sacrifice the post so that leads on to my questions-
What is the best way to cut the post so that it can be removed (ie how many cuts and in what direction?)
What is the best thing to use? I have hacksaws etc but someone did mention a Dremel with a metal cutting bit. My big fear is cutting down to the seat tube and being unable to cut enough of the post still in the frame to remove it.Simply put I don’t want a cut seat post that still won’t come out!
Any suggestions as to cutting (or any radical new approaches I may not have tried yet) would be more than welcome.
Thanks
Marty
