Handlebars
  • #21528
    Jonslr88
    I apparently need a wider set of bars to open up the chest and improve my breathing. Current width is 42cm. This has come about after a bike fitting and I now think this may be a good improvement. The question is how wide do bars go and what width should I choose?
  • #796055
    Jonslr88
    Thanks.
    Thanks.
    #796053
    wellcoordinated
    The wider you go the less
    The wider you go the less aero you’ll be, if anything go narrower! If you do go wider, any improvements in breathing (if any) will be lost to the wind. Also you’ll be squeezing your shoulder blades, so you risk upper back problems.
